S5120V2-28P-SI SSH login failed
2017-11-03提问
  • 1收藏,2825浏览
原先使用S5120-28P-SI型号,配置hwtacacs+CiscoACS5.3认证服务器,使用均正常。
替换成S5120V2-28P-SI后, 登陆login failed
查看log
%Nov 3 16:55:09:962 2017 Virtuos-SHA-10F-SW-9 SSHS/6/SSHS_LOG: Accepted password for hedongjie from 10.0.11.77 port 12274.
%Nov 3 16:55:11:025 2017 Virtuos-SHA-10F-SW-9 SSHS/6/SSHS_CONNECT: SSH user hedongjie (IP: 10.0.11.77) connected to the server successfully.
%Nov 3 16:55:11:357 2017 Virtuos-SHA-10F-SW-9 LOGIN/5/LOGIN_FAILED: hedongjie failed to log in from 10.0.11.77.
%Nov 3 16:55:14:403 2017 Virtuos-SHA-10F-SW-9 SSHS/6/SSHS_LOG: User hedongjie logged out from 10.0.11.77 port 12274.
%Nov 3 16:55:14:404 2017 Virtuos-SHA-10F-SW-9 SSHS/6/SSHS_DISCONNECT: SSH user hedongjie (IP: 10.0.11.77) disconnected from the server.
PS: public-key已经生产,尝试本地local账号ssh可以成功。
连CiscoACS使用Tacacs认证失败
相关配置信息如下:
# line vty 0 4
 authentication-mode scheme
 user-role network-admin
 user-role network-operator
 protocol inbound ssh
 ssh server enable
 ssh server authentication-timeout 120
hwtacacs scheme tacacs_virtuos
 primary authentication 10.0.20.250
 primary authorization 10.0.20.250
 key authentication cipher $c$3$bsNYrCs********QqLYEuTzMUccfOI0k=
 key authorization cipher $c$3$gucDCU2********gJSBDuBnffcMmWtAs=
 user-name-format without-domain
domain system
 authentication login hwtacacs-scheme tacacs_virtuos local
 authorization login hwtacacs-scheme tacacs_virtuos local
 authentication default radius-scheme radius_virtuos
 authorization default radius-scheme radius_virtuos
粉丝:29人 关注:3人
建议收集诊断,debug hwtacacs all,终端信息拨打400.
zhiliao_52012 知了小白
>debugging hwtacacs all
>terminal debugging
> terminal monitor
开启后没有任何信息显示。
