portal认证失败,提示用户不存在或用户没有添加到服务
2018-12-06提问
  • 1收藏,3098浏览
portal服务器是:172.20.9.50
imc侧是根据案例配置的
这是接入侧的配置
 domain default enable portal
 portal server myportal ip 172.20.9.50 key cipher $c$3$5LF/c7jbZ4+AwwmA3fiGZV8a5IwpeQ== url http://172.20.9.50:8080/portal
portal free-rule 0 source ip any destination ip 172.20.9.165 mask 255.255.255.255
portal free-rule 5 source ip any destination ip 172.20.10.100 mask 255.255.255.255
portal free-rule 10 source ip any destination ip 172.20.10.101 mask 255.255.255.255
portal free-rule 20 source ip any destination ip 172.20.219.254 mask 255.255.255.255
radius scheme imc
 primary authentication 172.20.9.50
 primary accounting 172.20.9.50
 key authentication cipher $c$3$vSoM2uEoDicZPczNdJ5xENLUc7pJAg==
 key accounting cipher $c$3$B5yY+EESFEhWb56SMygRF442o1fBKQ==
 user-name-format without-domain
domain portal
 authentication portal radius-scheme imc
 authorization portal radius-scheme imc
 accounting portal radius-scheme imc
 access-limit disable state active idle-cut disable self-service-url disable
interface Vlan-interface219 (客户端侧的vlan)
 ip address 172.20.219.254 255.255.255.0
 portal server myportal method direct portal nas-ip 172.20.9.254
粉丝:14人 关注:4人
检查接入设备IP和EIA中是否一致,用户服务是否带后缀,接入用户是不是在EIA中
