交换机命令行进不去
2018-12-11提问
  • 0收藏,1174浏览
iLeasy 三段
粉丝:3人 关注:3人
WP2008POE交换机重启后,按CTRL+C   D 都进不去
Starting...... Press Ctrl+D to access BASIC BOOT MENU Booting Normal Extend BootWare.... ******************************************************************************** * * * H3C WP2008 Switch BOOTROM, Version 110 * * * ******************************************************************************** Copyright (c) 2004-2017 New H3C Technologies Co., Ltd. Creation Date : Apr 17 2017, 16:17:22 CPU Clock Speed : 800MHz Memory Size : 512MB Flash Size : 256MB CPLD Version : 001 PCB Version : Ver.A Mac Address : 94282eb23748 Press Ctrl+B to access EXTENDED BOOT MENU...0 Loading the main image files... Loading file flash:/wp2000s-cmw710-system-r6113.bin............................. .........................Done. Loading file flash:/wp2000s-cmw710-boot-r6113.bin........Done. Image file flash:/wp2000s-cmw710-boot-r6113.bin is self-decompressing........... ............................................................................. ................................................................................ ................................................................................ ................................................................................ ................................................................................ ..........................................................................Done. System is starting... Board checking.......................LSP9LTSUU SDRAM fast selftest........................OK! Flash fast selftest........................OK! CPLD selftest..............................OK! Switch chip selftest.......................OK! PHY selftest...............................OK! Please check leds....................FINISHED! Cryptographic algorithms tests passed. Startup configuration file does not exist. Performing automatic configuration... Press CTRL_C or CTRL_D to break. Automatic configuration attempt: 1. Not ready for automatic configuration: no interface available. Waiting for the next... Automatic configuration attempt: 2. Interface used: Vlan-interface1. Enable DHCP client on Vlan-interface1. Vlan-interface1 failed to obtain IP address. Waiting for the next... Automatic configuration attempt: 3. Interface used: Vlan-interface1. Enable DHCP client on Vlan-interface1. Vlan-interface1 failed to obtain IP address. Waiting for the next... Automatic configuration attempt: 4. Interface used: Vlan-interface1. Enable DHCP client on Vlan-interface1. Vlan-interface1 failed to obtain IP address. Waiting for the next... Automatic configuration attempt: 5. Interface used: Vlan-interface1. Enable DHCP client on Vlan-interface1. Vlan-interface1 failed to obtain IP address. Waiting for the next... 嬛鬅瘥L稂狧z塥Hr勭T}丒id勎 Starting...... Press Ctrl+D to access BASIC BOOT MENU Booting Normal Extend BootWare.... ******************************************************************************** * * * H3C WP2008 Switch BOOTROM, Version 110 * * * ******************************************************************************** Copyright (c) 2004-2017 New H3C Technologies Co., Ltd. Creation Date : Apr 17 2017, 16:17:22 CPU Clock Speed : 800MHz Memory Size : 512MB Flash Size : 256MB CPLD Version : 001 PCB Version : Ver.A Mac Address : 94282eb23748 Press Ctrl+B to access EXTENDED BOOT MENU...0 Loading the main image files... Loading file flash:/wp2000s-cmw710-system-r6113.bin............................. .........................Done. Loading file flash:/wp2000s-cmw710-boot-r6113.bin........Done. Image file flash:/wp2000s-cmw710-boot-r6113.bin is self-decompressing........... ................................................................................ ................................................................................ ................................................................................ ................................................................................ ................................................................................ ..........................................................................Done. System is starting... Board checking.......................LSP9LTSUU SDRAM fast selftest........................OK! Flash fast selftest........................OK! CPLD selftest..............................OK! Switch chip selftest.......................OK! PHY selftest...............................OK! Please check leds....................FINISHED! Cryptographic algorithms tests passed. Startup configuration file does not exist. Performing automatic configuration... Press CTRL_C or CTRL_D to break. Automatic configuration attempt: 1. Not ready for automatic configuration: no interface available. Waiting for the next... Automatic configuration attempt: 2. Interface used: Vlan-interface1. Enable DHCP client on Vlan-interface1. Vlan-interface1 failed to obtain IP address. Waiting for the next... 嬛鬅瘥L稂狧jHr勭T}丒if屜 Starting...... Press Ctrl+D to access BASIC BOOT MENU Booting Normal Extend BootWare.... ******************************************************************************** * * * H3C WP2008 Switch BOOTROM, Version 110 * * * ******************************************************************************** Copyright (c) 2004-2017 New H3C Technologies Co., Ltd. Creation Date : Apr 17 2017, 16:17:22 CPU Clock Speed : 800MHz Memory Size : 512MB Flash Size : 256MB CPLD Version : 001 PCB Version : Ver.A Mac Address : 94282eb23748 Press Ctrl+B to access EXTENDED BOOT MENU...0 Loading the main image files... Loading file flash:/wp2000s-cmw710-system-r6113.bin............................. .........................Done. Loading file flash:/wp2000s-cmw710-boot-r6113.bin........Done. Image file flash:/wp2000s-cmw710-boot-r6113.bin is self-decompressing........... ................................................................................ ................................................................................ ................................................................................ ................................................................................ ................................................................................ ..........................................................................Done. System is starting... Board checking.......................LSP9LTSUU SDRAM fast selftest........................OK! Flash fast selftest........................OK! CPLD selftest..............................OK! Switch chip selftest.......................OK! PHY selftest...............................OK! Please check leds....................FINISHED! Cryptographic algorithms tests passed. Startup configuration file does not exist. Performing automatic configuration... Press CTRL_C or CTRL_D to break. Automatic configuration attempt: 1. Not ready for automatic configuration: no interface available. Waiting for the next... Automatic configuration attempt: 2. Interface used: Vlan-interface1. Enable DHCP client on Vlan-interface1. 嬙鬅饎\L矬z茺 躱(9垷 Starting...... Press Ctrl+D to access BASIC BOOT MENU Booting Normal Extend BootWare.... ******************************************************************************** * * * H3C WP2008 Switch BOOTROM, Version 110 * * * ******************************************************************************** Copyright (c) 2004-2017 New H3C Technologies Co., Ltd. Creation Date : Apr 17 2017, 16:17:22 CPU Clock Speed : 800MHz Memory Size : 512MB Flash Size : 256MB CPLD Version : 001 PCB Version : Ver.A Mac Address : 94282eb23748 Press Ctrl+B to access EXTENDED BOOT MENU...0 Loading the main image files... Loading file flash:/wp2000s-cmw710-system-r6113.bin............................. .........................Done. Loading file flash:/wp2000s-cmw710-boot-r6113.bin........Done. Image file flash:/wp2000s-cmw710-boot-r6113.bin is self-decompressing........... ................................................................................ ................................................................................ ................................................................................ ................................................................................ ................................................................................ ..........................................................................Done. System is starting... Board checking.......................LSP9LTSUU SDRAM fast selftest........................OK! Flash fast selftest........................OK! CPLD selftest..............................OK! Switch chip selftest.......................OK! PHY selftest...............................OK! Please check leds....................FINISHED! Cryptographic algorithms tests passed. Startup configuration file does not exist. Performing automatic configuration... Press CTRL_C or CTRL_D to break. Automatic configuration attempt: 1. Not ready for automatic configuration: no interface available. Waiting for the next... Automatic configuration attempt: 2. Interface used: Vlan-interface1. Enable DHCP client on Vlan-interface1. Vlan-interface1 failed to obtain IP address. Waiting for the next... Automatic configuration attempt: 3. Interface used: Vlan-interface1. Enable DHCP client on Vlan-interface1. 嬙鬅鸹L稂i覃 iDR# Starting...... Press Ctrl+D to access BASIC BOOT MENU Booting Normal Extend BootWare.... ******************************************************************************** * * * H3C WP2008 Switch BOOTROM, Version 110 * * * ******************************************************************************** Copyright (c) 2004-2017 New H3C Technologies Co., Ltd. Creation Date : Apr 17 2017, 16:17:22 CPU Clock Speed : 800MHz Memory Size : 512MB Flash Size : 256MB CPLD Version : 001 PCB Version : Ver.A Mac Address : 94282eb23748 Press Ctrl+B to access EXTENDED BOOT MENU...0 Loading the main image files... Loading file flash:/wp2000s-cmw710-system-r6113.bin............................. .........................Done.
寂东 九段
粉丝:134人 关注:3人
看你的界面还没启动完,V7平台启动比V5平台启动慢,多等会就好了
粉丝:3人 关注:1人
一直停留在这个状态,使用ctrl+D看下能不能终止
中止不了
iLeasy 发表时间:2018-12-11
回答问题的都不看问题描述,都说了,按CTRL+C +D都不行。没有一点实质性的回答吗?
这个没什么方法,可以测试下开机过程中ctrl+b能不能进入bootrom模式下,无非就几个情况,console无法输入,系统文件损坏,硬件问题,交替试下呗
atlantis 发表时间:2018-12-11
iLeasy 三段
粉丝:3人 关注:3人
去掉三个选项,重新按CTRL+D即可
