WP2008POE交换机重启后,按CTRL+C D 都进不去
Starting...... Press Ctrl+D to access BASIC BOOT MENU Booting Normal Extend BootWare.... ******************************************************************************** * * * H3C WP2008 Switch BOOTROM, Version 110 * * * ******************************************************************************** Copyright (c) 2004-2017 New H3C Technologies Co., Ltd. Creation Date : Apr 17 2017, 16:17:22 CPU Clock Speed : 800MHz Memory Size : 512MB Flash Size : 256MB CPLD Version : 001 PCB Version : Ver.A Mac Address : 94282eb23748 Press Ctrl+B to access EXTENDED BOOT MENU...0 Loading the main image files... Loading file flash:/wp2000s-cmw710-system-r6113.bin............................. .........................Done. Loading file flash:/wp2000s-cmw710-boot-r6113.bin........Done. Image file flash:/wp2000s-cmw710-boot-r6113.bin is self-decompressing........... ............................................................................. ................................................................................ ................................................................................ ................................................................................ ................................................................................ ..........................................................................Done. System is starting... Board checking.......................LSP9LTSUU SDRAM fast selftest........................OK! Flash fast selftest........................OK! CPLD selftest..............................OK! Switch chip selftest.......................OK! PHY selftest...............................OK! Please check leds....................FINISHED! Cryptographic algorithms tests passed. Startup configuration file does not exist. Performing automatic configuration... Press CTRL_C or CTRL_D to break. Automatic configuration attempt: 1. Not ready for automatic configuration: no interface available. Waiting for the next... Automatic configuration attempt: 2. Interface used: Vlan-interface1. Enable DHCP client on Vlan-interface1. Vlan-interface1 failed to obtain IP address. Waiting for the next... Automatic configuration attempt: 3. Interface used: Vlan-interface1. Enable DHCP client on Vlan-interface1. Vlan-interface1 failed to obtain IP address. Waiting for the next... Automatic configuration attempt: 4. Interface used: Vlan-interface1. Enable DHCP client on Vlan-interface1. Vlan-interface1 failed to obtain IP address. Waiting for the next... Automatic configuration attempt: 5. Interface used: Vlan-interface1. Enable DHCP client on Vlan-interface1. Vlan-interface1 failed to obtain IP address. Waiting for the next... 嬛鬅瘥L稂狧z塥Hr勭T}丒id勎 Starting...... Press Ctrl+D to access BASIC BOOT MENU Booting Normal Extend BootWare.... ******************************************************************************** * * * H3C WP2008 Switch BOOTROM, Version 110 * * * ******************************************************************************** Copyright (c) 2004-2017 New H3C Technologies Co., Ltd. Creation Date : Apr 17 2017, 16:17:22 CPU Clock Speed : 800MHz Memory Size : 512MB Flash Size : 256MB CPLD Version : 001 PCB Version : Ver.A Mac Address : 94282eb23748 Press Ctrl+B to access EXTENDED BOOT MENU...0 Loading the main image files... Loading file flash:/wp2000s-cmw710-system-r6113.bin............................. .........................Done. Loading file flash:/wp2000s-cmw710-boot-r6113.bin........Done. Image file flash:/wp2000s-cmw710-boot-r6113.bin is self-decompressing........... ................................................................................ ................................................................................ ................................................................................ ................................................................................ ................................................................................ ..........................................................................Done. System is starting... Board checking.......................LSP9LTSUU SDRAM fast selftest........................OK! Flash fast selftest........................OK! CPLD selftest..............................OK! Switch chip selftest.......................OK! PHY selftest...............................OK! Please check leds....................FINISHED! Cryptographic algorithms tests passed. Startup configuration file does not exist. Performing automatic configuration... Press CTRL_C or CTRL_D to break. Automatic configuration attempt: 1. Not ready for automatic configuration: no interface available. Waiting for the next... Automatic configuration attempt: 2. Interface used: Vlan-interface1. Enable DHCP client on Vlan-interface1. Vlan-interface1 failed to obtain IP address. Waiting for the next... 嬛鬅瘥L稂狧jHr勭T}丒if屜 Starting...... Press Ctrl+D to access BASIC BOOT MENU Booting Normal Extend BootWare.... ******************************************************************************** * * * H3C WP2008 Switch BOOTROM, Version 110 * * * ******************************************************************************** Copyright (c) 2004-2017 New H3C Technologies Co., Ltd. Creation Date : Apr 17 2017, 16:17:22 CPU Clock Speed : 800MHz Memory Size : 512MB Flash Size : 256MB CPLD Version : 001 PCB Version : Ver.A Mac Address : 94282eb23748 Press Ctrl+B to access EXTENDED BOOT MENU...0 Loading the main image files... Loading file flash:/wp2000s-cmw710-system-r6113.bin............................. .........................Done. Loading file flash:/wp2000s-cmw710-boot-r6113.bin........Done. Image file flash:/wp2000s-cmw710-boot-r6113.bin is self-decompressing........... ................................................................................ ................................................................................ ................................................................................ ................................................................................ ................................................................................ ..........................................................................Done. System is starting... Board checking.......................LSP9LTSUU SDRAM fast selftest........................OK! Flash fast selftest........................OK! CPLD selftest..............................OK! Switch chip selftest.......................OK! PHY selftest...............................OK! Please check leds....................FINISHED! Cryptographic algorithms tests passed. Startup configuration file does not exist. Performing automatic configuration... Press CTRL_C or CTRL_D to break. Automatic configuration attempt: 1. Not ready for automatic configuration: no interface available. Waiting for the next... Automatic configuration attempt: 2. Interface used: Vlan-interface1. Enable DHCP client on Vlan-interface1. 嬙鬅饎\L矬z茺 躱(9垷 Starting...... Press Ctrl+D to access BASIC BOOT MENU Booting Normal Extend BootWare.... ******************************************************************************** * * * H3C WP2008 Switch BOOTROM, Version 110 * * * ******************************************************************************** Copyright (c) 2004-2017 New H3C Technologies Co., Ltd. Creation Date : Apr 17 2017, 16:17:22 CPU Clock Speed : 800MHz Memory Size : 512MB Flash Size : 256MB CPLD Version : 001 PCB Version : Ver.A Mac Address : 94282eb23748 Press Ctrl+B to access EXTENDED BOOT MENU...0 Loading the main image files... Loading file flash:/wp2000s-cmw710-system-r6113.bin............................. .........................Done. Loading file flash:/wp2000s-cmw710-boot-r6113.bin........Done. Image file flash:/wp2000s-cmw710-boot-r6113.bin is self-decompressing........... ................................................................................ ................................................................................ ................................................................................ ................................................................................ ................................................................................ ..........................................................................Done. System is starting... Board checking.......................LSP9LTSUU SDRAM fast selftest........................OK! Flash fast selftest........................OK! CPLD selftest..............................OK! Switch chip selftest.......................OK! PHY selftest...............................OK! Please check leds....................FINISHED! Cryptographic algorithms tests passed. Startup configuration file does not exist. Performing automatic configuration... Press CTRL_C or CTRL_D to break. Automatic configuration attempt: 1. Not ready for automatic configuration: no interface available. Waiting for the next... Automatic configuration attempt: 2. Interface used: Vlan-interface1. Enable DHCP client on Vlan-interface1. Vlan-interface1 failed to obtain IP address. Waiting for the next... Automatic configuration attempt: 3. Interface used: Vlan-interface1. Enable DHCP client on Vlan-interface1. 嬙鬅鸹L稂i覃 iDR# Starting...... Press Ctrl+D to access BASIC BOOT MENU Booting Normal Extend BootWare.... ******************************************************************************** * * * H3C WP2008 Switch BOOTROM, Version 110 * * * ******************************************************************************** Copyright (c) 2004-2017 New H3C Technologies Co., Ltd. Creation Date : Apr 17 2017, 16:17:22 CPU Clock Speed : 800MHz Memory Size : 512MB Flash Size : 256MB CPLD Version : 001 PCB Version : Ver.A Mac Address : 94282eb23748 Press Ctrl+B to access EXTENDED BOOT MENU...0 Loading the main image files... Loading file flash:/wp2000s-cmw710-system-r6113.bin............................. .........................Done.
(0)
去掉三个选项,重新按CTRL+D即可
(2)
感谢大神,就是这个问题
解决不忘说句666
一直停留在这个状态,使用ctrl+D看下能不能终止
(0)
确定你的邮箱还未认证,请认证邮箱或绑定手机后进行当前操作
