WX3010E无线控制器做802.1X验证问题~急~
2018-12-17提问
  • 1收藏,1246浏览
3010E今天改了VLAN和地址,之前做的802.1x改了下radius服务器地址,其他配置没变,改完后,用户认证失败,但服务器端能收到数据包,日志提示“网络策略服务器已拒绝授予某个用户的访问”,服务器端配置已检查过,没有问题,另一品牌AC也对接的服务器,可以正常入网,环境基本信息如下:
3010E通过VLAN1与上级网络互连,地址172.19.1.92/24,同时也是NAS客户端地址,在radius上已经填写完毕并启用,radius服务器地址172.22.21.15,AC与服务器通信正常,以下是配置脚本:
[H3C]dis cur
 version 5.20, Release 3507P22
 sysname H3C
 domain default enable ***.***
 telnet server enable
 dot1x
 dot1x authentication-method eap
 mac-authentication timer offline-detect 180
 mac-authentication domain ***.***
 wlan auto-ap enable
 wlan auto-persistent enable
 password-recovery enable
vlan 1
vlan 8
vlan 10
vlan 20
vlan 23 to 24
vlan 58
vlan 62
vlan 152
vlan 156
vlan 200 to 201
radius scheme system
 server-type extended
 primary authentication 172.22.21.15
 primary accounting 172.22.21.15
 key authentication cipher $c$3$+rDeKpMthm87IQariwjmbBCrDt3tH0hPDw==
 key accounting cipher $c$3$EuQC0Cf2dT7eYq1R3TopALBCWifMHNl7Kw==
 user-name-format without-domain
radius scheme syste,
radius scheme ***.***
radius scheme sys
domain ***.***
 authentication lan-access local
 access-limit disable
 state active
 idle-cut disable
 self-service-url disable
domain ***.***
 authentication lan-access radius-scheme system
 authorization lan-access radius-scheme system
 accounting lan-access radius-scheme system
 access-limit enable 2048
 state active
 idle-cut disable
domain system
 state active
 idle-cut disable
dhcp server ip-pool 1
 network 172.16.1.0 mask 255.255.255.0
 gateway-list 172.16.1.1
 dns-list 114.114.114.114
user-group system
 group-attribute allow-guest
local-user 286c071a9a85
 password cipher $c$3$Bb2g23aKxkSlLWHdQ9e318JUUwg0gh/+SjOTIgqyCA==
 service-type lan-access
local-user 2b6c071a4c62
 password cipher $c$3$MLRVpQwO2LSBt+ZhL0EUxrjDOElNqGwz8I7ix/fPWg==
local-user 38bc1a951d20
 password cipher $c$3$AyhBIRy95D9p/Ax2uNJ4IZeghTuwjI4vZhYJQQzzgQ==
local-user 6814019bef09
 password cipher $c$3$rTw/J2DJJi+Mo3tIJ2JWpiXgLBEsBgF1A91Resb7vg==
local-user c85b76720f10
 password cipher $c$3$HRSO266Ad15TLGPYTHXQUjiHZ24TofO+arOIT4TPmQ==
local-user f0b429ba3d90
 password cipher $c$3$AEneMuYyfCJ7puvtYd0Hh/xKZO6WWFK3OEq9wwHj7g==
local-user f0b429ba3eaa
 password cipher $c$3$khD30UX/NUd9wILbpHDBYFQU5J7kUL4MXJ6owLUxag==
local-user guest
 password cipher $c$3$IrlPgPyUcrh2xzGaxos/ev49BCsdsryO
 authorization-attribute level 3
 service-type telnet
 service-type web
wlan rrm
 dot11a mandatory-rate 6 12 24
 dot11a supported-rate 9 18 36 48 54
 dot11b mandatory-rate 1 2
 dot11b supported-rate 5.5 11
 dot11g mandatory-rate 1 2 5.5 11
 dot11g supported-rate 6 9 12 18 24 36 48 54
wlan service-template 1 clear
wlan service-template 10 crypto
 ssid mcczy
 bind WLAN-ESS 0
 cipher-suite tkip
 cipher-suite ccmp
 security-ie rsn
 service-template enable
wlan service-template 100 clear
wlan service-template 2 clear
 ssid mcczy-guest
 bind WLAN-ESS 2
wlan service-template 3 crypto
 ssid mcczy-admin
 beacon ssid-hide
wlan service-template 4 clear
 ssid mcczy-admin
 beacon ssid-hide
 bind WLAN-ESS 3
wlan ap-group default_group
 ap 3c8c-40f2-2cc0
 ap 3c8c-40f2-2e00
 ap 3c8c-40f2-2ec0
 ap 3c8c-40f6-a940
 ap 3c8c-40f6-ae40
 ap 3c8c-40f6-be60
 ap 3c8c-40f6-bf40
 ap 3c8c-40f6-bfc0
 ap 3c8c-40f6-c020
 ap 3c8c-40f6-c2c0
 ap 3c8c-40f6-c3a0
 ap 3c8c-40f6-c3c0
interface Bridge-Aggregation1
 port link-type trunk
 port trunk permit vlan all
interface NULL0
interface Vlan-interface1
 ip address 172.19.1.92 255.255.255.0
interface Vlan-interface8
 ip address 192.168.8.112 255.255.255.0
interface Vlan-interface10
 ip address 172.16.1.1 255.255.255.0
interface Vlan-interface24
 ip address 192.168.24.3 255.255.255.0
interface Vlan-interface58
interface Vlan-interface62
interface Vlan-interface152
interface Vlan-interface156
interface Vlan-interface201
 port link-aggregation group 1
interface WLAN-ESS0
 port access vlan 58
 port-security port-mode userlogin-secure-ext
 port-security tx-key-type 11key
 undo dot1x handshake
 dot1x mandatory-domain ***.***
 undo dot1x multicast-trigger
interface WLAN-ESS1
interface WLAN-ESS2
 port access vlan 62
interface WLAN-ESS3
 port access vlan 201
 port-security port-mode mac-authentication
interface WLAN-ESS4
interface WLAN-MESH1
interface WLAN-MESH8
wlan ap 3c8c-40f2-2cc0 model WA2620i-AGN id 10
 serial-id 219801A0CMC159000001
 radio 1
  service-template 1
  service-template 2
  service-template 4
  service-template 10
  radio enable
 radio 2
  service-template 1
  service-template 2
  service-template 4
  service-template 10
  radio enable
wlan ap 3c8c-40f2-2e00 model WA2620i-AGN id 2
 serial-id 219801A0CMC159000011
 radio 1
  service-template 1
  service-template 2
  service-template 4
  service-template 10
  radio enable
 radio 2
  service-template 1
  service-template 2
  service-template 4
  service-template 10
  radio enable
wlan ap 3c8c-40f2-2ec0 model WA2620i-AGN id 7
 serial-id 219801A0CMC159000017
 radio 1
  service-template 1
  service-template 2
  service-template 4
  service-template 10
  radio enable
 radio 2
  service-template 1
  service-template 2
  service-template 4
  service-template 10
  radio enable
wlan ap 3c8c-40f6-a940 model WA2620i-AGN id 11
 serial-id 219801A0CMC159001336
 radio 1
  service-template 1
  service-template 2
  service-template 4
  service-template 10
  radio enable
 radio 2
  service-template 1
  service-template 2
  service-template 4
  service-template 10
  radio enable
wlan ap 3c8c-40f6-ae40 model WA2620i-AGN id 4
 serial-id 219801A0CMC159001376
 radio 1
  service-template 1
  service-template 2
  service-template 4
  service-template 10
  radio enable
 radio 2
  service-template 1
  service-template 2
  service-template 4
  service-template 10
  radio enable
wlan ap 3c8c-40f6-be60 model WA2620i-AGN id 3
 serial-id 219801A0CMC159001505
 radio 1
  service-template 1
  service-template 2
  service-template 4
  service-template 10
  radio enable
 radio 2
  service-template 1
  service-template 2
  service-template 4
  service-template 10
  radio enable
wlan ap 3c8c-40f6-bf40 model WA2620i-AGN id 5
 serial-id 219801A0CMC159001512
 radio 1
  service-template 1
  service-template 2
  service-template 4
  service-template 10
  radio enable
 radio 2
  service-template 1
  service-template 2
  service-template 4
  service-template 10
  radio enable
wlan ap 3c8c-40f6-bfc0 model WA2620i-AGN id 9
 serial-id 219801A0CMC159001516
 radio 1
  service-template 1
  service-template 2
  service-template 4
  service-template 10
  radio enable
 radio 2
  service-template 1
  service-template 2
  service-template 4
  service-template 10
  radio enable
wlan ap 3c8c-40f6-c020 model WA2620i-AGN id 8
 serial-id 219801A0CMC159001519
 radio 1
  service-template 1
  service-template 2
  service-template 4
  service-template 10
  radio enable
 radio 2
  service-template 1
  service-template 2
  service-template 4
  service-template 10
  radio enable
wlan ap 3c8c-40f6-c2c0 model WA2620i-AGN id 6
 serial-id 219801A0CMC159001541
 radio 1
  service-template 1
  service-template 2
  service-template 4
  service-template 10
  radio enable
 radio 2
  service-template 1
  service-template 2
  service-template 4
  service-template 10
  radio enable
wlan ap 3c8c-40f6-c3a0 model WA2620i-AGN id 1
 serial-id 219801A0CMC159001548
 radio 1
  service-template 1
  service-template 2
  service-template 4
  service-template 10
  radio enable
 radio 2
  service-template 1
  service-template 2
  service-template 4
  service-template 10
  radio enable
wlan ap 3c8c-40f6-c3c0 model WA2620i-AGN id 12
 serial-id 219801A0CMC159001549
 radio 1
  service-template 1
  service-template 2
  service-template 4
  service-template 10
  radio enable
 radio 2
  service-template 1
  service-template 2
  service-template 4
  service-template 10
  radio enable
wlan ips
 malformed-detect-policy default
 signature deauth_flood signature-id 1
 signature broadcast_deauth_flood signature-id 2
 signature disassoc_flood signature-id 3
 signature broadcast_disassoc_flood signature-id 4
 signature eapol_logoff_flood signature-id 5
 signature eap_success_flood signature-id 6
 signature eap_failure_flood signature-id 7
 signature pspoll_flood signature-id 8
 signature cts_flood signature-id 9
 signature rts_flood signature-id 10
 signature addba_req_flood signature-id 11
 signature-policy default
 countermeasure-policy default
 attack-detect-policy default
 virtual-security-domain default
 ip route-static 0.0.0.0 0.0.0.0 172.19.1.80
 ip route-static 172.0.0.0 255.0.0.0 172.19.1.80
 ip route-static 192.168.0.0 255.255.0.0 192.168.8.254
 undo info-center enable
 dhcp server forbidden-ip 172.16.1.1 172.16.1.2
 dhcp enable
 arp-snooping enable
 wlan ap-authentication enable
 wlan ap-authentication method serial-id
user-interface con 0
user-interface vty 0 4
 authentication-mode scheme
 user privilege level 3
return
粉丝:7人 关注:0人
服务器侧配置是否也是不带域名,进行认证。EAP认证的话,是否服务器侧有导入证书?
服务器侧带域名,没有证书
橘子熟了 发表时间:2018-12-17
user-name-format without-domain,AC侧配置的是不带域名,请两边配置保持一致。还有EAP认证的话服务器侧是需要证书的应该。
ChanyiC 发表时间:2018-12-17
