进行远端802.1x认证,接入设备始终不和RADIUS服务交互报文。RADIUS服务器是我司IMC配置的。接入设备是HP 5130-24G-PoE+-4SFP+ (370W) EI。
接入设备能ping通服务器,接入设备上RADIUS配置没有问题。
RADIUS scheme name: 123
Index: 4
Primary Auth Server:
Host name: Not Configured
IP : 20.1.1.1 Port: 1812 State: Active
VPN : Not configured
Primary Acct Server:
IP : 20.1.1.1 Port: 1813 State: Active
debugging RADIUS 后,没有产生RADIUS报文。
debugging dot1x后,
*Jan 8 21:37:38:050 2013 HP DOT1X/7/EVENT: [b4b6-861e-d3e1:VLAN2:GE1/0/1] BE is in Idle state.
*Jan 8 21:37:38:050 2013 HP DOT1X/7/EVENT: [b4b6-861e-d3e1:VLAN2:GE1/0/1] PAE is in Aborting state.
*Jan 8 21:37:38:051 2013 HP DOT1X/7/EVENT: [b4b6-861e-d3e1:VLAN2:GE1/0/1] BE is in Initialize state.
*Jan 8 21:37:38:051 2013 HP DOT1X/7/EVENT: [b4b6-861e-d3e1:VLAN2:GE1/0/1] PAE is in Disconnect state.
*Jan 8 21:37:38:051 2013 HP DOT1X/7/EVENT: [b4b6-861e-d3e1:VLAN2:GE1/0/1] BE is in Idle state.
*Jan 8 21:37:38:052 2013 HP DOT1X/7/EVENT: PORT_SM[GE1/0/1] received event DOT1X_PSM_E_USER_UNAUTHORED.
*Jan 8 21:38:19:474 2013 HP DOT1X/7/EVENT: [b4b6-861e-d3e1:VLAN2:GE1/0/1] Processing new mac event .
*Jan 8 21:38:19:476 2013 HP DOT1X/7/EVENT: [b4b6-861e-d3e1:VLAN2:GE1/0/1] PAE is in Disconnect state.
*Jan 8 21:38:19:476 2013 HP DOT1X/7/EVENT: [b4b6-861e-d3e1:VLAN2:GE1/0/1] BE is in Initialize state.
*Jan 8 21:38:19:477 2013 HP DOT1X/7/EVENT: [b4b6-861e-d3e1:VLAN2:GE1/0/1] PAE is in Restart state.
*Jan 8 21:38:19:477 2013 HP DOT1X/7/EVENT: [b4b6-861e-d3e1:VLAN2:GE1/0/1] BE is in Idle state.
*Jan 8 21:38:19:478 2013 HP DOT1X/7/EVENT: [b4b6-861e-d3e1:VLAN2:GE1/0/1] PAE is in Connecting state.
*Jan 8 21:38:19:478 2013 HP DOT1X/7/EVENT: [b4b6-861e-d3e1:VLAN2:GE1/0/1] PAE is in Authenticating state.
*Jan 8 21:38:19:479 2013 HP DOT1X/7/EVENT: [b4b6-861e-d3e1:VLAN2:GE1/0/1] BE is in Request state.
*Jan 8 21:38:19:479 2013 HP DOT1X/7/EVENT: Sending EAP Packet (identifier 1, type 1)
*Jan 8 21:38:19:480 2013 HP DOT1X/7/PACKET:
所以为啥不能和服务器交互RADIUS报文?还有就是PAE,BE这些是啥,在配置指导上没有说过这些
(0)
确定你的邮箱还未认证,请认证邮箱或绑定手机后进行当前操作
怎么同步呢
把你的配置发出来。
