HCL+DHCP
2019-01-03提问
  • 1收藏,1637浏览
逍遥 零段
路由器的接口G0/0和交换机G0/6间是单臂路由,设置了4个子接口,VLAN10 和VLAN30 客户端通过DHCP获得IP地址
问题
接在路由器的GE_0/1的PC想实现和VLAN10通过DHCP获得地址路由器该如何配置
实现AP1和AP2在同一网段,可以互通
请各位大神多指教,谢谢!!!!
路由器的设置
# version 7.1.075, Alpha 7571
 # sysname H3C
 # dhcp enable
 # vlan 1
 # vlan 10 to 40
 # dhcp server ip-pool vlan10
 gateway-list 192.168.10.1
 network 192.168.10.0 mask 255.255.255.0
dns-list 8.8.8.8
 forbidden-ip 192.168.10.1
 # dhcp server ip-pool vlan30
gateway-list 192.168.30.1
network 192.168.30.0 mask 255.255.255.0
dns-list 8.8.8.8
forbidden-ip 192.168.30.1
 # interface GigabitEthernet0/0.1 ip address 192.168.10.1 255.255.255.0
 vlan-type dot1q vid 10
dhcp server apply ip-pool vlan10
# interface GigabitEthernet0/0.2 ip address 192.168.20.1 255.255.255.0
 vlan-type dot1q vid 20
# interface GigabitEthernet0/0.3 ip address 192.168.30.1 255.255.255.0
 vlan-type dot1q vid 30
dhcp server apply ip-pool vlan30
# interface GigabitEthernet0/0.4 ip address 192.168.1.1 255.255.255.0
vlan-type dot1q vid 40
交换机的设置
 # sysname H3C
 # vlan 10 description AP
 # vlan 20 description IPC
# vlan 30 description MI-VIDEO
# vlan 40 description PLC-SERVER
 # interface GigabitEthernet1/0/1 port link-mode bridge
port access vlan 20
combo enable fiber
 # interface GigabitEthernet1/0/2 port link-mode bridge
port access vlan 20
combo enable fiber
# interface GigabitEthernet1/0/3 port link-mode bridge
port access vlan 10
combo enable fiber
# interface GigabitEthernet1/0/4 port link-mode bridge
port access vlan 40
combo enable fiber
# interface GigabitEthernet1/0/5 port link-mode bridge
port access vlan 30
combo enable fiber
# interface GigabitEthernet1/0/6 port link-mode bridge
port link-type trunk
port trunk permit vlan all
combo enable fiber
呵呵 九段
粉丝:27人 关注:0人
把详细需求梳理一下,都是基础配置。
粉丝:15人 关注:0人
如果是MSR3620这个设备不支持接口划为bridge,模拟器是可以的,但实际使用切换为bridge只支持做EVI,要实现AP1与AP2同网段,可以再MSR上增加交换模块支持trunk等,或者将其替换为交换机设备。
