MSR36004G获取不了IP
2019-01-09提问
  • 1收藏,686浏览
Service status changed from Limited to No Service
 Controller Cellular4/0: Service status changed from No Service to Service Available.
Controller Cellular4/0: The network connection switched to 3G
 Controller Cellular4/0: IPv4 dialing failed. Reason: Data call failed
Current Service Status: Service Available Registration Status: Registered Current Service: Combined Current Roaming Status: Home Current Data Bearer Technology: Unknown Network Selection Mode: Automatic Current IP address Mode: Cellular-alloc Current IPV6 address Mode: Unknown Mobile Network Name: UNICOM Mobile Country Code (MCC): 460 Mobile Network Code (MNC): 01 Location Area Code (LAC): 61863
获取不了IP,端口一直是down 的是不是信号不好哦,4G APN认证模式是没有认证 ,客户直接给了卡啥都没有给,要不要APN认证啊
使用display cellular x/0查看一下接口的详细信息  发过来看看
[LuZhouNan-SFZ672]display cellular 4/0 Cellular4/0: Modem State: Hardware Information: Model: U9300C Manufacturer: LONGSUNG Modem Firmware Version: QB30001.1.8_MX10(0016_1.4.1_L0122) International Mobile Equipment Identity (IMEI): 862808037804443 International Mobile Subscriber Identity (IMSI): 460066520087346 Mobile Equipment Identifier (MEID): 99000911783169 Hardware Version: 10000 Factory Serial Number (FSN): 60000012S171587P04207 Modem Status: Online Modem Status: IPv4 Unkown. Modem Status: IPv6 Unkown. Profile Information: Profile index: 1 PDP Type: IPv4v6 Header Compression: Off Data Compression: Off Authentication: NONE * - Default profile Profile index: 2 PDP Type: IPv4v6 Header Compression: Off Data Compression: Off Access Point Name (APN): 3GWAP Authentication: NONE Profile index: 3 PDP Type: IPv4v6 Header Compression: Off Data Compression: Off Access Point Name (APN): WONET Authentication: NONE Network Information: Current Service Status: Service Available Registration Status: Registered Current Service: Combined Current Roaming Status: Home Current Data Bearer Technology: Unknown Network Selection Mode: Automatic Current IP address Mode: Cellular-alloc Current IPV6 address Mode: Unknown Mobile Network Name: UNICOM Mobile Country Code (MCC): 460 Mobile Network Code (MNC): 01 Location Area Code (LAC): 61863 Cell ID: 176104594 Radio Information: Technology Preference: No preference specified (AUTO) Technology Selected: UMTS Configured LTE Band = 1,3,5,8,38,39,40,41 WCDMA related info: Current RSSI: -104 dBm Current ECIO: -11 dBm Modem Security Information: PIN Verification: Disabled PIN Status: PIN Requirement Disabled Number of PIN Retries Remaining: 3 Number of PUK Retries Remaining: 10 SIM Status: OK ICCID: 89860619000013696483 Error Information: IPv4 dialing failed: 0x0e: Data call failed IPv6 dialing failed: N/A GPS Information: GPS Info: GPS State: Enabled GPS Mode Configured: Standalone Latitude(WGS84): 0 Deg 0 Min 0.00 Sec North Longitude(WGS84): 0 Deg 0 Min 0.00 Sec East Timestamp (UTC): 00/00/0000 00:00:00 Local time: 00/00/0000 00:00:00 Heading: 0.00, Velocity Horiz: 0.00, Velocity Vert: 0.00 Height (MSL): 0.00 m Satellite Info:
zhiliao_fDATa 发表时间:2019-01-09
Current RSSI: -104 dBm 4G信号太弱了,看一下路由器有没有安装天线,如果装了确定下信号强度。
zhiliao_G8mAp 发表时间:2019-01-09
zhiliao_fDATa 知了小白
