关键字
发布时间
SW 5560
2017-11-13提问
  • 0收藏,1417浏览
新交换机报如下错误,面板SYS亮红灯%Jan  1 00:20:34:906 2013 H3C DEV/1/FAN_DIRECTION_NOT_PREFERRED: Fan 1 airflow direction is not preferred on slot 1, please check it.
%Jan  1 00:21:53:306 2013 H3C DEV/1/FAN_DIRECTION_NOT_PREFERRED: Fan 2 airflow direction is not preferred on slot 1, please check it.
%Jan  1 00:21:54:906 2013 H3C DEV/1/FAN_DIRECTION_NOT_PREFERRED: Fan 1 airflow direction is not preferred on slot 1, please check it.
%Jan  1 00:23:13:307 2013 H3C DEV/1/FAN_DIRECTION_NOT_PREFERRED: Fan 2 airflow direction is not preferred on slot 1, please check it.
%Jan  1 00:23:14:906 2013 H3C DEV/1/FAN_DIRECTION_NOT_PREFERRED: Fan 1 airflow direction is not preferred on slot 1, please check it.
%Jan  1 00:24:33:307 2013 H3C DEV/1/FAN_DIRECTION_NOT_PREFERRED: Fan 2 airflow direction is not preferred on slot 1, please check it.
%Jan  1 00:24:34:906 2013 H3C DEV/1/FAN_DIRECTION_NOT_PREFERRED: Fan 1 airflow direction is not preferred on slot 1, please check it.
%Jan  1 00:25:53:325 2013 H3C DEV/1/FAN_DIRECTION_NOT_PREFERRED: Fan 2 airflow direction is not preferred on slot 1, please check it.
%Jan  1 00:25:54:949 2013 H3C DEV/1/FAN_DIRECTION_NOT_PREFERRED: Fan 1 airflow direction is not preferred on slot 1, please check it.
%Jan  1 00:27:13:306 2013 H3C DEV/1/FAN_DIRECTION_NOT_PREFERRED: Fan 2 airflow direction is not preferred on slot 1, please check it.
Kylin 九段
粉丝:16人 关注:6人
风扇风向不对。
<Sysname> display fan
 Slot 1:
 Fan 1:
 State    : FanDirectionFault
 Airflow Direction: Port-to-power
 Prefer Airflow Direction: Power-to-port
 Fan 2:
表1-6 display fan命令显示信息描述表
Slot 1
设备的成员编号
Fan 1
设备上风扇的编号
风扇状态:
·     Absent:风扇不在位
·     Normal:风扇正常工作
·     Fault:风扇故障
·     FanDirectionFault:用户期望的风道方向与风扇框的实际风道方向不一致(适用于除S5560-30S-EIS5560-54S-EI以外的其他机型。)
Airflow Direction
风扇模块的实际风道方向:
·     Port-to-power:风扇从端口侧向电源侧抽风,即风向从前向后
·     Power-to-port:风扇从电源侧向端口侧吹风,即风向从后向前
用户期望的风扇模块的风道方向:
1.1.32  fan prefer-direction
fan prefer-direction命令用来配置用户期望的风扇模块的风道方向。
undo fan prefer-direction命令用来恢复缺省情况。
fan prefer-direction slot slot-number power-to-port | port-to-power }
undo fan prefer-direction slot slot-number
配置IRF中成员设备1的用户期望的风扇模块的风道方向为port-to-power
[Sysname] fan prefer-direction slot 1 port-to-power
