S5100交换机启动过程中报驱动错误
2019-01-16提问
  • 1收藏,1120浏览
<XYZR-S5110-16> System is starting... Press Ctrl+D to access BASIC-BOOTWARE MENU Booting Normal Extend BootWare The Extend BootWare is self-decompressing.......................Done! **************************************************************************** * * * H3C S5110-28P BootWare, Version 1.10 * * * **************************************************************************** Copyright (c) 2004-2014 Hangzhou H3C Technologies Co., Ltd. Compiled Date : Jun 5 2014 11:34:07 CPU Type : MIPS4kec CPU L1 Cache : 16KB CPU Clock Speed : 500MHz Memory Type : DDR3 SDRAM Memory Size : 128MB Memory Speed : 300MHz BootWare Size : 3MB Flash Size : 32MB BootWare Validating... Press Ctrl+B to enter extended boot menu... Starting to get the main application file--flash:/s5110_28p-cmw520-r1109. bin!........................................................................ ........................ The main application file is self-decompressing............................. ............................................................................ ............................................................................ ............................................................................ ............................................................................ ............................................................................ ............................................................................ ............................................................................ ............................................................................ ............................................................................ ............................................................................ ............................................................................ ............................................................................ ............................................................................ ............................................................................ ............................................................................ ............................................................................ ............................................................................ ............................................................................ ............................................................................ ........................................................................... Done! System application is starting... Drv_InternalSetStpPort: call Hal_GetStpPortState fail! Drv_Port_SetMstpStateByInstance: call Drv_InternalSetStpPort(4,16)fail! Drv_Set_MstpPortState: call Drv_Port_SetMstpStateByInstance(3,16,3)fail! Drv_InternalSetStpPort: call Hal_GetStpPortState fail! Drv_PortSetStpStateInAllInstances: call Drv_InternalSetStpPort(4,16,0) fail! Drv_STP_BlockPort: call Drv_PortSetStpStateInAllInstances fail! Drv_Set_AggrPortBlock: call Drv_STP_BlockPort(PortIndex:16, State:2) fail! Drv_InternalSetStpPort: call Hal_GetStpPortState fail! Drv_Port_SetMstpStateByInstance: call Drv_InternalSetStpPort(4,17)fail! Drv_Set_MstpPortState: call Drv_Port_SetMstpStateByInstance(3,17,3)fail! Drv_InternalSetStpPort: call Hal_GetStpPortState fail! Drv_PortSetStpStateInAllInstances: call Drv_InternalSetStpPort(4,17,0) fail! Drv_STP_BlockPort: call Drv_PortSetStpStateInAllInstances fail! Drv_Set_AggrPortBlock: call Drv_STP_BlockPort(PortIndex:17, State:2) fail! Drv_InternalSetStpPort: call Hal_GetStpPortState fail! Drv_Port_SetMstpStateByInstance: call Drv_InternalSetStpPort(4,18)fail! Drv_Set_MstpPortState: call Drv_Port_SetMstpStateByInstance(3,18,3)fail! Drv_InternalSetStpPort: call Hal_GetStpPortState fail! Drv_PortSetStpStateInAllInstances: call Drv_InternalSetStpPort(4,18,0) fail! Drv_STP_BlockPort: call Drv_PortSetStpStateInAllInstances fail! Drv_Set_AggrPortBlock: call Drv_STP_BlockPort(PortIndex:18, State:2) fail! Drv_InternalSetStpPort: call Hal_GetStpPortState fail! Drv_Port_SetMstpStateByInstance: call Drv_InternalSetStpPort(4,19)fail! Drv_Set_MstpPortState: call Drv_Port_SetMstpStateByInstance(3,19,3)fail! Drv_InternalSetStpPort: call Hal_GetStpPortState fail! Drv_PortSetStpStateInAllInstances: call Drv_InternalSetStpPort(4,19,0) fail! Drv_STP_BlockPort: call Drv_PortSetStpStateInAllInstances fail! Drv_Set_AggrPortBlock: call Drv_STP_BlockPort(PortIndex:19, State:2) fail! Drv_InternalSetStpPort: call Hal_GetStpPortState fail! Drv_Port_SetMstpStateByInstance: call Drv_InternalSetStpPort(4,20)fail! Drv_Set_MstpPortState: call Drv_Port_SetMstpStateByInstance(3,20,3)fail! Drv_InternalSetStpPort: call Hal_GetStpPortState fail! Drv_PortSetStpStateInAllInstances: call Drv_InternalSetStpPort(4,20,0) fail! Drv_STP_BlockPort: call Drv_PortSetStpStateInAllInstances fail! Drv_Set_AggrPortBlock: call Drv_STP_BlockPort(PortIndex:20, State:2) fail! Drv_InternalSetStpPort: call Hal_GetStpPortState fail! Drv_Port_SetMstpStateByInstance: call Drv_InternalSetStpPort(4,21)fail! Drv_Set_MstpPortState: call Drv_Port_SetMstpStateByInstance(3,21,3)fail! Drv_InternalSetStpPort: call Hal_GetStpPortState fail! Drv_PortSetStpStateInAllInstances: call Drv_InternalSetStpPort(4,21,0) fail! Drv_STP_BlockPort: call Drv_PortSetStpStateInAllInstances fail! Drv_Set_AggrPortBlock: call Drv_STP_BlockPort(PortIndex:21, State:2) fail! Drv_InternalSetStpPort: call Hal_GetStpPortState fail! Drv_Port_SetMstpStateByInstance: call Drv_InternalSetStpPort(4,22)fail! Drv_Set_MstpPortState: call Drv_Port_SetMstpStateByInstance(3,22,3)fail! Drv_InternalSetStpPort: call Hal_GetStpPortState fail! Drv_PortSetStpStateInAllInstances: call Drv_InternalSetStpPort(4,22,0) fail! Drv_STP_BlockPort: call Drv_PortSetStpStateInAllInstances fail! Drv_Set_AggrPortBlock: call Drv_STP_BlockPort(PortIndex:22, State:2) fail! Drv_InternalSetStpPort: call Hal_GetStpPortState fail! Drv_Port_SetMstpStateByInstance: call Drv_InternalSetStpPort(4,23)fail! Drv_Set_MstpPortState: call Drv_Port_SetMstpStateByInstance(3,23,3)fail! Drv_InternalSetStpPort: call Hal_GetStpPortState fail! Drv_PortSetStpStateInAllInstances: call Drv_InternalSetStpPort(4,23,0) fail! Drv_STP_BlockPort: call Drv_PortSetStpStateInAllInstances fail! Drv_Set_AggrPortBlock: call Drv_STP_BlockPort(PortIndex:23, State:2) fail! User interface aux0 is available. Press ENTER to get started.
粉丝:50人 关注:5人
硬件有问题,更换处理吧。
寂东 九段
粉丝:225人 关注:3人
已经起来了,你敲回车进去后,把设备恢复出厂值,再断电重启看看还有没有报错
