S5120-48P-EI
2017-11-16提问
  • 1收藏,2020浏览
公司用的交换机密码忘记了,又不能恢复出厂,请问还有别的方法进去吗?
墨峰 九段
粉丝:51人 关注:6人
可以尝试如下方法能不能恢复,如果不能的话就没有办法了。
如果用户设置的console登录口令丢失,又不能通过telnet方式修改口令,可以使用以下解决方法:删除启动文件。具体操作步骤如下:
1.   进入BOOTROM菜单
Press Ctrl+B to enter Boot Menu...4
Please input BootRom password:
   BOOT MENU
1. Download application file to device
2. Select application file to boot
3. Display all files in device
4. Delete file from device
5. Modify BootRom password
0. Reboot
Enter your choice(0-5):
键入Ctrl+B组合键进入BOOTROM菜单。
2、导出设备配置文件到外部TFTP/FTP服务器
BOOT MENU
0. Reboot
Enter your choice(0-5):                   //此处输入CTRL+Y键后敲击ENTER
Please select application file upload choices:
1. Upload file from Flash via TFTP protocol
2. Upload file from CF card via TFTP protocol
0. Return to boot menu
Enter your choice(0-2): 1           //选择1,使用TFTPF方式导出配置文件
Load File name           :sda startup.cfg
Switch IP address        :192.168.0.36 172.16.0.1
Server IP address        :192.168.0.30 172.16.0.2
 //根据实际情况输入配置文件名称,设备地址、TFTP服务器地址
Are you sure to upload file to server? Yes or No (Y/N):Y
//选择Y
Load file from flash to sdram...done!
Uploading...done!
BOOTROM菜单下,按CTRL+Y键后敲击ENTER,按照提示设置TFTP服务器,导出用户配置。
3、删除当前启动配置文件
Enter your choice(0-2): 0                             //回到Bootrom菜单
   BOOT MENU
0. Reboot
Enter your choice(0-5): 4                       //删除当前启动配置文件
Flash:/
Number.    Size(B)   Time                 Name
1          4588      Nov/05/2014 08:08:27 private-data.txt
2          864024    Jul/19/2012 09:23:35 io_mon.txt
3          12610     Aug/13/2012 13:46:44 patch_mpu.bin
4          970       Aug/09/2013 09:07:44 patchstate
5          62930     Nov/05/2014 08:08:51 config.cwmp
6          4         Oct/12/2014 11:47:27 snmpboots
7          33367493  Oct/15/2014 10:06:24 s7500e-cmw520-r6708p09.app
8          21413     Nov/05/2014 08:09:19 startup.cfg
9          735       Aug/07/2012 10:17:45 hostkey
10         4843      Dec/06/2010 17:15:40 config.cfg
11         591       Aug/07/2012 10:17:53 serverkey
12         2954      Sep/11/2012 07:03:21 irf.cfg
13         7918      Jun/20/2000 04:37:39 triple.cfg
14         3807      Nov/05/2014 08:09:09 system.xml
15         1411      Feb/24/2010 15:07:49 startupwangchen.cfg
16         16413     Nov/05/2014 08:08:37 qosindex
17         429436    Sep/22/2014 13:30:03 lsqsrp2xb05301.btw
18         6524      Nov/01/2012 15:58:55 mplstest.cfg
19         7345      May/15/2012 12:21:26 iccrunning.cfg
Free space: 29672448 bytes
The current application file is:cfa0:/s7500e-cmw520-r6708p08.app
The backup application file is:cfa0:/s7500e-cmw520-r6105.app
Please input the file number to delete :8       //启动配置文件对应序号8
The file you selected is flash:/startup.cfg, delete it? Yes or No(Y/N)Y
Deleting.....done!                                            //选择Y
在导出用户配置之后,此步骤用以删除启动文件,让设备重新以空配置启动(如果设备配置无需保存,可以直接删除设备启动文件,无需进行第二步的配置备份)。
   4、重启设备
           BOOT MENU
5.
粉丝:38人 关注:5人
楼上说的办法就可以,搞不定的话加我qq
