H3C SecPath U200-CM 1-4端口灯不亮
2017-11-18提问
  • 1收藏,1734浏览
连接网线后1-4口灯不亮,不能传输数据,通过CONSOLE口连接,输入密码后提示:
BootWare Validating... Application program does not exist. Please input BootWare password:***** Note: The current operating device is flash Enter < Storage Device Operation > to select device. ===========================<EXTEND-BOOTWARE MENU>=========================== |<1> Boot System | |<2> Enter Serial SubMenu | |<3> Enter Ethernet SubMenu | |<4> File Control | |<5> Modify BootWare Password | |<6> Skip Current System Configuration | |<7> BootWare Operation Menu | |<8> Clear Super Password | |<9> Storage Device Operation | |<0> Reboot | ============================================================================ Enter your choice(0-9):
选择1 Boot System 后提示:
Enter your choice(0-9): 1 Starting to get the main application file--flash:/main.bin! The main application file does not exist--flash:/main.bin! Starting to get the backup application file--flash:/backup.app! The backup application file does not exist--flash:/backup.app! Starting to get the secure application file--flash:/secure.app! The secure application file does not exist--flash:/secure.app! Booting App fails!
lemon 四段
版本丢失,bootrom下重新传下版本就好了。
能帮我发一下H3C SecPath U200-CM的版本吗?我从官网上下不了,谢谢!
nxycliuzj 发表时间:2017-11-18
防火墙重启的时候没有 Press Ctrl+B to enter extended boot menu… ,按ctrl+b也没有反应,怎么办?
nxycliuzj 发表时间:2017-11-19
nxycliuzj 知了小白
谢谢!
