H3C WA2620iAGN 瘦AP怎么改成胖AP
2017-11-22提问
  • 1收藏,4360浏览
跪求大神帮忙
知了小白
粉丝: 关注:
版本链接:
http://sso.h3c.com/LoginPage.aspx?Culture=zh-cn&RequestTicket=UwBhAG0AcABsAGUAUwBpAHQAZQA%3d%24aAB0AHQAcAA6AC8ALwB3AHcAdwAuAGgAMwBjAC4AYwBvAG0ALwBjAG4ALwBkAF8AMgAwADEANQAxADEALwA4ADkANgA5ADcAMQBfADMAMAAwADAANQBfADQAMAAuAGgAdABtAA%3d%3d%24MgAwADEANwAtADEAMQAtADIAMgAgADIAMwA6ADIANgA6ADQAMwA%3d%24hW8v7WTIgWKxsfxOW2izgA%3d%3d
下载账户:yx800 密码:01230123    TFTP工具可以百度到
<WA2620i-AGN>ap-mode fat
 Change working mode will reboot system, do you want to continue? [Y/N]:y
 Change working mode to FAT (please ensure FAT app is present)? [Y/N]:y
两分钟后自动重启,重启的时候按CTRL+B进入BTW菜单:
=======================<EXTEND-BOOTWAREMENU>==================
|<1> Boot System                                                           |
|<2> Enter Serial SubMenu                                                  |
|<3> Enter Ethernet SubMenu                                                |
|<4> File Control                                                          |
|<5> Restore to Factory Default Configuration                              |
|<6> Skip Current System Configuration                                     |
|<7> BootWare Operation Menu                                               |
|<8> Clear Super Password                                                  |
|<9> Storage Device Operation                                              |
|<0> Reboot        |
Ctrl+C: Display Copyright
Ctrl+F: Format File System
Enter your choice(0-9): 3
===================<Enter Ethernet SubMenu>==========================
|Note:the operating device is flash                                        |
|<1> Download Application Program To SDRAM And Run                         |
|<2> Update Main Application File                                          |
|<3> Update Backup Application File                                        |
|<4> Update Secure Application File                                        |
|<5> Modify Ethernet Parameter                                             |
|<0> Exit To Main Menu                                                     |
|<Ensure The Parameter Be Modified Before Downloading!>                    |
Enter your choice(0-5): 5
=================<ETHERNET PARAMETER SET>======================
|Note:       '.' = Clear field.                                            |
|            '-' = Go to previous field.                                   |
|          Ctrl+D = Quit.                                                  |==================================================================
Protocol (FTP or TFTP) :ftp ftp
Load File Name         :WA2600A-CMW520-R1308P11-FAT.bin
                       :wa2600a_fat.bin
Target File Name       :WA2600A-CMW520-R1308P11-FAT.bin
                       :wa2600a_fat.bin
Server IP Address      :192.168.20.1 192.168.20.1
Local IP Address       :192.168.20.2 192.168.20.2
Gateway IP Address     :0.0.0.0
FTP User Name          :111111 111111
FTP User Password      :111111 111111
Enter your choice(0-5): 2
Loading.....................................................................
...Done!
9090048 bytes downloaded!
Updating File flash:/wa2600a_fat.bin........................................
........................Done!
Enter your choice(0-5): 0
=============<EXTEND-BOOTWARE MENU>===========================
|<1> Boot System                                                           |
|<4> File Control                                                          |
|<0> Reboot        |
Enter your choice(0-9): 1
重启完成之后:
此时已经是肥AP,但是并未完全成功,如果可以成功重启AP,才算重启成功
只需要下个TFTP就可以了吗
zhiliao_65456 发表时间:2017-11-22
不知道怎么弄 能在线教我吗 跪求
能方便加个微信吗
就是第一不会
zhiliao_65456 发表时间:2017-11-23
