H3C S5500 Series+忘记账户密码
2017-11-28提问
  • 1收藏,5590浏览
忘记登录的账号密码,及开机密码,想重置,恢复出厂设置,请详细的步骤,谢谢!
粉丝:29人 关注:3人
  1. 进入BOOTROM菜单
Press Ctrl+B to enter Boot Menu...4
Please input BootRom password:
   BOOT MENU
1. Download application file to device
2. Select application file to boot
3. Display all files in device
4. Delete file from device
5. Modify BootRom password
0. Reboot
Enter your choice(0-5):
键入Ctrl+B组合键进入BOOTROM菜单。
2、导出设备配置文件到外部TFTP/FTP服务器
BOOT MENU
0. Reboot
Enter your choice(0-5):                   //此处输入CTRL+Y键后敲击ENTER
Please select application file upload choices:
1. Upload file from Flash via TFTP protocol
2. Upload file from CF card via TFTP protocol
0. Return to boot menu
Enter your choice(0-2): 1           //选择1,使用TFTPF方式导出配置文件
Load File name           :sda startup.cfg
Switch IP address        :192.168.0.36 172.16.0.1
Server IP address        :192.168.0.30 172.16.0.2
 //根据实际情况输入配置文件名称,设备地址、TFTP服务器地址
Are you sure to upload file to server? Yes or No (Y/N):Y
//选择Y
Load file from flash to sdram...done!
Uploading...done!
BOOTROM菜单下,按CTRL+Y键后敲击ENTER,按照提示设置TFTP服务器,导出用户配置。
3、删除当前启动配置文件
Enter your choice(0-2): 0                             //回到Bootrom菜单
   BOOT MENU
0. Reboot
Enter your choice(0-5): 4                       //删除当前启动配置文件
Flash:/
Number.    Size(B)   Time                 Name
1          4588      Nov/05/2014 08:08:27 private-data.txt
2          864024    Jul/19/2012 09:23:35 io_mon.txt
3          12610     Aug/13/2012 13:46:44 patch_mpu.bin
4          970       Aug/09/2013 09:07:44 patchstate
5          62930     Nov/05/2014 08:08:51 config.cwmp
6          4         Oct/12/2014 11:47:27 snmpboots
7          33367493  Oct/15/2014 10:06:24 s7500e-cmw520-r6708p09.app
8          21413     Nov/05/2014 08:09:19 startup.cfg
9          735       Aug/07/2012 10:17:45 hostkey
10         4843      Dec/06/2010 17:15:40 config.cfg
11         591       Aug/07/2012 10:17:53 serverkey
12         2954      Sep/11/2012 07:03:21 irf.cfg
13         7918      Jun/20/2000 04:37:39 triple.cfg
14         3807      Nov/05/2014 08:09:09 system.xml
15         1411      Feb/24/2010 15:07:49 startupwangchen.cfg
16         16413     Nov/05/2014 08:08:37 qosindex
17         429436    Sep/22/2014 13:30:03 lsqsrp2xb05301.btw
18         6524      Nov/01/2012 15:58:55 mplstest.cfg
19         7345      May/15/2012 12:21:26 iccrunning.cfg
Free space: 29672448 bytes
The current application file is:cfa0:/s7500e-cmw520-r6708p08.app
The backup application file is:cfa0:/s7500e-cmw520-r6105.app
Please input the file number to delete :8       //启动配置文件对应序号8
The file you selected is flash:/startup.cfg, delete it? Yes or No(Y/N)Y
Deleting.....done!                                            //选择Y
在导出用户配置之后,此步骤用以删除启动文件,让设备重新以空配置启动(如果设备配置无需保存,可以直接删除设备启动文件,无需进行第二步的配置备份)。
   4、重启设备
           BOOT MENU
0. Reboot
Enter your choice(0-5): 0                             //选择0,重启设备
Starting......
RAMLine.....OK
System is booting...............
      设备将以空配置重启,使用console口成功登陆设备后可以设置新的的console密码,如需要刷回原来的配置,切记先删除console口登陆的相关设置。
呵呵 九段
粉丝:27人 关注:0人
重启,Ctrl+B,忽略bootware密码和配置,直接进入系统即可~
苏北星 知了小白
这个, 我也遇过呀   ,学习了
