s12508 二三层组播配置问题
2019-04-10提问
  • 1收藏,1912浏览
一台s12508 v5版本,上联三层组播跑pimsm,下联跑二层组播igmp-snooping,在配置下联vlan开启igmp-snooping,提示设备已经开启了三层组播,不能同时开启二层组播
设备配置见附件
zhiliao_AyYHO 知了小白
接口配置报错:
[CDN12508]vlan 502
[CDN12508-vlan502]igmp-snooping enable
  <cr>
  Failed to enable IGMP Snooping in the VLAN, because IGMP, IGMP proxying, PIM-DM or PIM-SM has been enabled on the VLAN interface.
关于组播的设备配置
 multicast routing-enable
igmp-snooping
 host-aging-time 300
vlan 1
vlan 14
 description TO-TV组播播出交换机互联
vlan 15
vlan 16
 description dhcp_server互联
vlan 502
 description tv-zubo
interface LoopBack0
 ip address 10.253.174.21 255.255.255.255
 igmp enable
 igmp version 3
 igmp static-group 232.100.1.1
 igmp static-group 232.100.1.7
 igmp static-group 232.100.1.2
 igmp static-group 232.100.1.4
 igmp static-group 232.100.1.3
 igmp static-group 232.100.1.5
 igmp static-group 232.100.1.6
 igmp static-group 232.100.1.8
 igmp static-group 232.100.1.9
 igmp static-group 232.100.1.10
 igmp static-group 232.100.1.11
 igmp static-group 232.100.1.12
 igmp static-group 232.100.1.13
 igmp static-group 232.100.11.6
 pim sm
interface Vlan-interface14
 ip address 10.253.176.1 255.255.255.252
 igmp enable
 igmp version 3
 pim sm
interface Vlan-interface502
 ip address 10.253.176.13 255.255.255.252
 igmp enable
 igmp version 3
 pim sm
ospf 1 router-id 10.253.174.21
igmp
 version 3
pim
 static-rp 10.253.174.21 preferred
 ssm-policy 2005
[CDN12508-vlan502]
下边二层跑的igmp v2 与12508对接的接口12508是否需要igmp改成v2
粉丝:110人 关注:0人
igmp-snooping只需要在下面纯二层网络中的下联接入设备开启即可,12508下联口开启 pim sm和igmp enable即可
ps,没有附件
接口配置报错: [CDN12508]vlan 502 [CDN12508-vlan502]igmp-snooping enable <cr> [CDN12508-vlan502]igmp-snooping enable Failed to enable IGMP Snooping in the VLAN, because IGMP, IGMP proxying, PIM-DM or PIM-SM has been enabled on the VLAN interface. 关于组播的设备配置 multicast routing-enable igmp-snooping host-aging-time 300 # vlan 1 vlan 14 description TO-享TV组播播出交换机互联 # vlan 15 # vlan 16 description dhcp_server互联 # vlan 502 description tv-zubo # interface LoopBack0 ip address 10.253.174.21 255.255.255.255 igmp enable igmp version 3 igmp static-group 232.100.1.1 igmp static-group 232.100.1.7 igmp static-group 232.100.1.2 igmp static-group 232.100.1.4 igmp static-group 232.100.1.3 igmp static-group 232.100.1.5 igmp static-group 232.100.1.6 igmp static-group 232.100.1.8 igmp static-group 232.100.1.9 igmp static-group 232.100.1.10 igmp static-group 232.100.1.11 igmp static-group 232.100.1.12 igmp static-group 232.100.1.13 igmp static-group 232.100.11.6 pim sm # interface Vlan-interface14 ip address 10.253.176.1 255.255.255.252 igmp enable igmp version 3 pim sm interface Vlan-interface502 ip address 10.253.176.13 255.255.255.252 igmp enable igmp version 3 pim sm # ospf 1 router-id 10.253.174.21 # igmp version 3 # pim static-rp 10.253.174.21 preferred ssm-policy 2005 # [CDN12508-vlan502] 下边二层跑的igmp v2 与12508对接的接口12508是否需要igmp改成v2
zhiliao_AyYHO 发表时间:2019-04-10
建议都设置成同一个版本
知了知了 发表时间:2019-04-10
