请教MSR830-10-WINNET的单臂路由设置
2019-04-29提问
  • 1收藏,1647浏览
第一台H3C S1526二层交换机的18端口,设置为VLAN 20,并且设置为TAG,将级联端口25设置为tag,物理连接到路由器的GigabitEthernet0/2(计划网段:10.0.20.1 24)
第二台H3C S1526二层交换机的18端口,设置为VLAN 30,并且设置为TAG,将级联端口25设置为tag,物理连接到路由器的GigabitEthernet0/3
(计划网段:10.0.30.1 24)
没有三层交换机,现想实现 Vlan20Vlan30下的PC机互通,计划通过H3C MSR830-10 WINNET来做单臂路由来实现。
参考的这个贴子:***.***/s/blog_90d5d6c90100yscf.html
现在执行到添加子接口,就已经出错,请各位大佬,帮看下,这个命令是敲错了吗? 接下来该怎么设置呢?
如果后期自己学习,能否推荐一个型号的三层交换机,性能不讲究,主要用于练习。感谢!
H3C S1526二层交换机(管理IP地址:10.0.1.13)的当前设置如下:
目前的路由器display cur信息如下:
[H3C]display ip routing-table
Routing Tables: Public
        Destinations : 7        Routes : 7
0.0.0.0/0           Static 70   0            192.168.1.1     GE0/0
10.0.1.0/24         Direct 0    0            10.0.1.1        Vlan1
10.0.1.1/32         Direct 0    0            127.0.0.1       InLoop0
192.168.1.0/24      Direct 0    0            192.168.1.150   GE0/0
192.168.1.150/32    Direct 0    0            127.0.0.1       InLoop0
[H3C]dis
 % Incomplete command found at '^' position.
[H3C]display
[H3C]display cur
 version 5.20, Release 2516P19
 sysname H3C
 password-control enable
 undo password-control aging enable
 undo password-control history enable
 password-control length 6
 password-control login-attempt 3 exceed lock-time 10
 password-control password update interval 0
 password-control login idle-time 0
 password-control complexity user-name check
 domain default enable system
 dns proxy enable
 dar p2p signature-file flash:/p2p_default.mtd
 ndp enable
 ntdp enable
 cluster enable
 port-security enable
 password-recovery enable
vlan 1
domain system
 access-limit disable
 state active
 idle-cut disable
 self-service-url disable
dhcp server ip-pool vlan1 extended
 network ip range 10.0.1.102 10.0.1.254
 network mask 255.255.255.0
 gateway-list 10.0.1.1
 dns-list 10.0.1.1
user-group system
 group-attribute allow-guest
local-user admin
 authorization-attribute level 3
 service-type telnet
 service-type web
cwmp
 undo cwmp enable
interface Cellular0/0
 async mode protocol
 link-protocol ppp
 tcp mss 1024
interface NULL0
interface Vlan-interface1
 ip address 10.0.1.1 255.255.255.0
 tcp mss 1024
 dhcp server apply ip-pool vlan1
interface GigabitEthernet0/0
 port link-mode route
 nat outbound
 ip address dhcp-alloc
interface GigabitEthernet0/1
 tcp mss 1024
interface GigabitEthernet0/8
 tcp mss 1024
interface GigabitEthernet0/9
 tcp mss 1024
interface GigabitEthernet0/2
 port link-mode bridge
interface GigabitEthernet0/3
interface GigabitEthernet0/4
interface GigabitEthernet0/5
interface GigabitEthernet0/6
interface GigabitEthernet0/7
 dhcp enable
 nms primary monitor-interface GigabitEthernet0/0
 load xml-configuration
 load tr069-configuration
user-interface con 0
user-interface tty 13
user-interface vty 0 4
 authentication-mode scheme
return
粉丝:36人 关注:1人
0/2口是交换口,需要切换到路由模式才能建立子接口
interface GigabitEthernet0/2.1
system-view System View: return to User View with Ctrl+Z. [H3C]port link-mode route ^ % Incomplete command found at '^' position. [H3C]
aguiblog 发表时间:2019-04-29
先进入接口 int g0/2
你还要我怎样 发表时间:2019-04-29
system-view System View: return to User View with Ctrl+Z. [H3C]int g0/2 [H3C-GigabitEthernet0/2]port link-mode route [H3C-GigabitEthernet0/2]intface ethernet g0/2.1 ^ % Unrecognized command found at '^' position. [H3C-GigabitEthernet0/2] 高人,我刚刚学习这些内容,小白一个。能否教下完整的将g0/2建立子接口的命令?
aguiblog 知了小白
还是出错,望高人指点
<H3C>system-view
[H3C]int g0/2
