胖ap如何开启上行信道完整性检测功能?
2019-05-18提问
  • 1收藏,1620浏览
粉丝:17人 关注:18人
ap如何能够实现配置上行链路完整性检测功能,即上行链路断开信号自动消失
ap能够实现配置上行链路完整性检测功能: wlan uplink-interface ethernet 1/0/1
2、配置上行链路完整性检测功能。
[H3C] wlan uplink-interface ethernet 1/0/1
配置文件
[H3C]display current-confuguration
 version 5.20, Ess 1104P02
 sysname H3C
 domain default enable system
 wlan uplink-interface Ethernet1/0/1
vlan 1
domain system
 access-limit disable
 state active
 idle-cut disable
 self-service-url disable
wlan rrm
 dot11a mandatory-rate 6 12 24
 dot11a supported-rate 9 18 36 48 54
 dot11b mandatory-rate 1 2
 dot11b supported-rate 5.5 11
 dot11g mandatory-rate 1 2 5.5 11
 dot11g supported-rate 6 9 12 18 24 36 48 54
wlan service-template 1 clear
 ssid H3C
 authentication-method open-system
 service-template enable
interface NULL0
interface WLAN-BSS1
interface WLAN-Radio1/0/1
service-template 1 interface wlan-bss 1
interface WLAN-Radio1/0/2
user-interface con 0
user-interface vty 0 4
return
