IMC备份配置生效
2017-12-12提问
  • 1收藏,2705浏览
127.0.0.1@perf_db_imc_perf_ifbackup=0, 127.0.0.1@monitor_db_imc_monitor_iftrans=0, 210.34.81.11@dam_dam_ifrestore=1, 127.0.0.1@config_db_imc_config_ifbackup=0, 127.0.0.1@config_db_imc_config_iftrans=0, 127.0.0.1@reportplat_db_reportplat_ifrestore=1, 127.0.0.1@monitor_db_imc_monitor_ifbackup=0, 127.0.0.1@perf_db_imc_perf_ifrestore=1, 127.0.0.1@unba_master_unba_master_ifbackup=0, 210.34.81.11@dam_dam_iftrans=0, 210.34.81.4@unba_slave_unba_slave_ifbackup=1, 210.34.81.9@wlan_db_imc_wsm_iftrans=0, 210.34.81.3@ead_ead_iftrans=0, 210.34.81.4@unba_slave_unba_slave_iftrans=0, 127.0.0.1@monitor_db_imc_monitor_ifrestore=1, 127.0.0.1@unba_master_unba_master_ifrestore=1, 210.34.81.4@unba_slave_unba_slave_ifrestore=1, 127.0.0.1@reportplat_db_reportplat_iftrans=0, 127.0.0.1@reportplat_db_reportplat_ifbackup=0} 2017-12-12 21:48:41 [INFO ] [AWT-EventQueue-0] [com.h3c.imc.deploy.dma.DBManConfiguration::openConfigDialog(472)] openConfigDialog(parent, dbAddress):updateDefaultParams() start 2017-12-12 21:48:41 [INFO ] [AWT-EventQueue-0] [com.h3c.imc.deploy.dma.IPConfigFileManager::a(168)] Start loading server-addr.xml configuration file 2017-12-12 21:48:41 [INFO ] [AWT-EventQueue-0] [com.h3c.imc.deploy.dma.IPConfigFileManager::a(232)] Load server-addr.xml configuration file succeeded 2017-12-12 21:48:41 [INFO ] [AWT-EventQueue-0] [com.h3c.imc.deploy.dma.DBManConfiguration::openConfigDialog(474)] openConfigDialog(parent, dbAddress):updateDefaultParams() end 2017-12-12 21:48:41 [INFO ] [AWT-EventQueue-0] [com.h3c.imc.deploy.dma.IPConfigFileManager::a(168)] Start loading server-addr.xml configuration file 2017-12-12 21:48:41 [INFO ] [AWT-EventQueue-0] [com.h3c.imc.deploy.dma.IPConfigFileManager::a(232)] Load server-addr.xml configuration file succeeded 2017-12-12 21:48:41 [INFO ] [AWT-EventQueue-0] [com.h3c.imc.deploy.dma.DBManConfiguration::g(1065)] saveDbmanConfig():success end 2017-12-12 21:48:41 [ERROR] [SwingWorker-pool-2-thread-1] [com.h3c.imc.deploy.dma.DBManConfiguration$k::b(5362)] DBMan is backupping
粉丝:14人 关注:4人
应该不是以管理员身份运行的,解决方案请尝试以管理员身份运行部署监控代理。重启dbman进程。再尝试
仁风 四段
这个可以收集一下imc安装路径下\dbman\etc目录\dbman\log目录下联系新华三400电话确认一下,另外检查一下服务器的数据库是否正常运行
