H3C s5008pv2交换机配置看不懂
2019-05-28提问
  • 1收藏,1871浏览
<H3C>e
version 5.20, Release 5203P05
sysname H3C
domain default enable system
telnet server enable
password-recovery enable
vlan 1
vlan 600
vlan 611
domain system
access-limit disable
state active
idle-cut disable
self-service-url disable
user-group system
group-attribute allow-guest
interface NULL0
interface Vlan-interface1
ip address dhcp-alloc client-identifier mac Vlan-interface1
interface Ethernet1/0/1
port access vlan 600
interface Ethernet1/0/2
interface Ethernet1/0/3
interface Ethernet1/0/4
interface Ethernet1/0/5
interface Ethernet1/0/6
interface Ethernet1/0/7
interface Ethernet1/0/8
port access vlan 611
interface GigabitEthernet1/0/9
port link-type trunk
port trunk permit vlan all
ip route-static 0.0.0.0 0.0.0.0 10.10.100.1
load xml-configuration
load tr069-configuration
user-interface aux 0
user-interface vty 0 15
Return
请大神帮忙看下都是什么意思!~哪些配置是主要的
主要配置了vlan,1-5口vlan600,6-7默认vlan(vlan1),8口vlan611,9口上联交换机,交换机的管理地址是通过上层的DHCP获得的
粉丝:6人 关注:43人
1-5端口属于vlan 600,8端口属于vlan611,9口是上联口,vlan 1地址是自动获取的,还配置了一条指向10.10.100.1默认路由,但是vlan600和611网关也不再这个交换机上,配置路由也没什么用啊。两个vlan都是二层上去的。
