H3C防火墙的配置
2019-05-29提问
  • 1收藏,2164浏览
我要实现的是把原来的一个局域网内的数据库服务器 跟局域网内的客户端分离开来,中间加一个防火墙。
现在我把两个eth端口,一个配置到了trust,一个是untrust,然后在两个端口加了acl分别限制1433以外的ip包通过。
可现在功能没能实现。下边儿是配置脚本,谁帮我看看怎么回事儿呢?
firewall packet-filter enable
firewall packet-filter default permit
insulate
bridge enable
bridge 1 enable
firewall statistic system enable
radius scheme system
server-type extended
domain system
local-user admin
password simple admin
service-type telnet
level 3
acl number 3000
rule 1 permit tcp source-port eq 1433 destination-port eq 1433
rule 2 deny tcp source-port lt 1433 destination-port lt 1433
rule 3 deny tcp source-port gt 1433 destination-port gt 1433
interface Aux0
async mode flow
interface Ethernet0/0
bridge-set 1
bridge vlanid-transparent-transmit enable
firewall packet-filter 3000 inbound
firewall packet-filter 3000 outbound
interface Ethernet0/1
bridge-set 1
interface Ethernet0/2
bridge-set 1
interface Ethernet0/3
interface Ethernet0/4
interface Encrypt1/0
interface Bridge-template1
ip address 192.168.1.254 255.255.255.0
interface NULL0
firewall zone local
set priority 100
firewall zone trust
add interface Ethernet0/0
add interface Bridge-template1
set priority 85
firewall zone untrust
add interface Ethernet0/1
set priority 5
firewall zone DMZ
set priority 50
firewall interzone local trust
firewall interzone local untrust
firewall interzone local DMZ
firewall interzone trust untrust
firewall interzone trust DMZ
firewall interzone DMZ untrust
firewall defend ip-spoofing
firewall defend land
firewall defend smurf
firewall defend fraggle
firewall defend winnuke
firewall defend icmp-redirect
firewall defend icmp-unreachable
firewall defend source-route
firewall defend route-record
firewall defend tracert
firewall defend ping-of-death
firewall defend tcp-flag
firewall defend ip-frag
firewall defend ip-fragment
firewall defend large-icmp
firewall defend teardrop
firewall defend ip-sweep
firewall defend port-scan
firewall defend arp-spoofing
firewall defend arp-flood
firewall defend frag-flood
firewall defend syn-flood enable
firewall defend udp-flood enable
firewall defend icmp-flood enable
很抱歉的告诉你。H3C的防火墙当你应用在桥模式时,基于二层以上的协议均不好使。
因为当防火墙工作在桥也就是二层时,三层以上数据无法识别出来。也就做不了控制。基本相当于废物。
你将此防火墙修改成路由模式就好了
