  • 1收藏,1690浏览
服务器为uis-8000刀片,通过vc映射给服务器的fcoe存储,https://zhiliao.h3c.com/Theme/details/24130 ***.***/z/q880019514.htm根据知了中提到需要yum安装fcoe,由于我的服务器无法连接外网,所以我挂载的为Centos7.0/7.4/7.5进行安装,然后提示[root@cloud02 ~]# yum install fcoe-utils Loaded plugins: fastestmirror Loading mirror speeds from cached hostfile Package fcoe-utils-1.0.32-1.el7.x86_64 already installed and latest version Nothing to do,有了一个,现在我可以看到/etc/fcoe这个目录,但是里边是空的,之后继续安装知了中进行部署在执行完ifup eno3后提示:/etc/sysconfig/network-scripts/ifcfg-eno3: line 1: //BOOTPROTO=none: No such file or directory /etc/sysconfig/network-scripts/ifcfg-eno3: line 2: //OnBOOT=yes: No such file or directory /etc/sysconfig/network-scripts/ifcfg-eno3: line 1: //BOOTPROTO=none: No such file or directory /etc/sysconfig/network-scripts/ifcfg-eno3: line 2: //OnBOOT=yes: No such file or directory ERROR : [/etc/sysconfig/network-scripts/ifup-eth] Device does not seem to be present, delaying initialization.之后执行fcoeadm -i命令也是不成功的,提示:fcoeadm: No action was taken Try 'fcoeadm --help' for more information.有人可以告诉我那设置的不对吗。
粉丝:51人 关注:20人
看了半天没看出来问题,建议咨询下400吧
400打了,他们没有在这样的环境部署过,现在还在确认是服务器方的问题,还是cloudos方的问题,
zhiliao_STR9K 发表时间:2019-05-31
centos 的安装,很多特性需要上网下载依赖包,提供上网环境重新测试看看或者拨打400
但是没有条件让服务器联网,400已经打了,他们也没装过这种环境的
