L2TP拨号失败
2019-07-02提问
  • 1收藏,3238浏览
LAC是客户的设备,没有权限登陆。LNS是我们华三的防火墙F5000-C。
安全策略全放通,L2TP拨号不成功,以下是debug信息;
<H3C>*Jul  2 11:50:04:219 2019 H3C IPFW/7/IPFW_PACKET: -COntext=1;
Delivering, interface = GigabitEthernet1/0/3
version = 4, headlen = 20, tos = 252
pktlen = 131, pktid = 51089, offset = 0, ttl = 250, protocol = 17
checksum = 20076, s = 192.20.0.9, d = 192.20.41.62
channelID = 0, vpn-InstanceIn = 0, vpn-InstanceOut = 0.
prompt: Forwarding IP packet to upper layer.
Payload: UDP
  source port = 1701, destination port = 1701
  checksum = 0x0000, length = 111.
*Jul  2 11:50:04:221 2019 H3C L2TPV2/7/CONTROL-PKT: -COntext=1;
 Received SCCRQ packet from port 1701 (length=103, Ns=0, Nr=0). Packet content:
 c8 02 00 67  00 00 00 00  00 00 00 00  80 08 00 00
 00 00 00 01  80 08 00 00  00 02 01 00  80 0f 00 00
 00 07 67 7a  6d 32 6d 6c  32 74 70 00  0c 00 00 00
 08 48 55 41  57 45 49 80  0a 00 00 00  03 00 00 00
 03 80 08 00  00 00 09 b1  8e 80 08 00  00 00 0a 00
 40 80 16 00  00 00 0b 26  6c cd 54 81  92 76 90 af
 10 9d 6c e7  f7 72 42
*Jul  2 11:50:04:222 2019 H3C L2TPV2/7/EVENT: -COntext=1;
 Parsed Message-Type AVP: 1.
 Parsed Protocol-Version AVP. Version=1, Revision=0.
*Jul  2 11:50:04:223 2019 H3C L2TPV2/7/EVENT: -COntext=1;
 Parsed Host-Name AVP: gzm2ml2tp.
 Parsed Vendor-Name AVP: HUAWEI.
*Jul  2 11:50:04:224 2019 H3C L2TPV2/7/EVENT: -COntext=1;
 Parsed Framing-Capabilities AVP: 3.
 Parsed Assigned-Tunnel-ID AVP: 45454.
 Parsed Receive-Window-Size AVP: 64.
*Jul  2 11:50:04:225 2019 H3C L2TPV2/7/EVENT: -COntext=1;
 Parsed Challenge AVP: 26 6c cd 54 81 92 76 90 af 10 9d 6c e7 f7 72 42
*Jul  2 11:50:04:225 2019 H3C L2TPV2/7/CONTROL-PKT: -COntext=1;
 Encapsulated Message-Type AVP:
 80 08 00 00  00 00 00 02
*Jul  2 11:50:04:226 2019 H3C L2TPV2/7/CONTROL-PKT: -COntext=1;
 Encapsulated Protocol-Version AVP:
*Jul  2 11:50:04:227 2019 H3C L2TPV2/7/CONTROL-PKT: -COntext=1;
 Encapsulated Host-Name AVP:
 80 09 00 00  00 07 48 33  43
 Encapsulated Framing-Capabilities AVP:
 80 0a 00 00  00 03 00 00  00 00
*Jul  2 11:50:04:228 2019 H3C L2TPV2/7/CONTROL-PKT: -COntext=1;
 Encapsulated Assigned-Tunnel-ID AVP:
 80 08 00 00  00 09 4f bf
*Jul  2 11:50:04:229 2019 H3C L2TPV2/7/CONTROL-PKT: -COntext=1;
 Encapsulated Bearer-Capabilities AVP:
 80 0a 00 00  00 04 00 00  00 03
 Encapsulated Receive-Window-Size AVP:
 80 08 00 00  00 0a 04 00
*Jul  2 11:50:04:230 2019 H3C L2TPV2/7/CONTROL-PKT: -COntext=1;
 Encapsulated Challenge AVP:
 80 16 00 00  00 0b c1 66  dc 5b 0e b4  01 ef 4a 1b
 57 10 29 29  a2 d9
*Jul  2 11:50:04:232 2019 H3C L2TPV2/7/CONTROL-PKT: -COntext=1;
 Encapsulated Challenge-Response AVP:
 80 16 00 00  00 0d e9 e0  0c 14 46 26  50 55 f6 57
 bb b2 58 70  3c f7
*Jul  2 11:50:04:233 2019 H3C L2TPV2/7/EVENT: -COntext=1;
 TunnelID=20415: Processed SCCRQ packet in Idle state, sent SCCRP packet and changed the tunnel state to Wait-connect.
*Jul  2 11:50:04:237 2019 H3C IPFW/7/IPFW_PACKET: -COntext=1;
pktlen = 66, pktid = 51090, offset = 0, ttl = 250, protocol = 17
checksum = 20140, s = 192.20.0.9, d = 192.20.41.62
Payload: UDP
  checksum = 0x0000, length = 46.
*Jul  2 11:50:04:238 2019 H3C L2TPV2/7/CONTROL-PKT: -COntext=1;
 Received StopCCN packet from port 1701 (TunnelID=20415, length=38, Ns=1, Nr=1). Packet content:
 c8 02 00 26  4f bf 00 00  00 01 00 01  80 08 00 00
 00 00 00 04  80 08 00 00  00 09 b1 8e  80 0a 00 00
 00 01 00 02  00 00
*Jul  2 11:50:04:239 2019 H3C L2TPV2/7/EVENT: -COntext=1;
 Parsed Message-Type AVP: 4.
 Parsed Result-Code AVP. Result-Code=2, Error-Code=0, Error-Message="".
*Jul  2 11:50:04:240 2019 H3C L2TPV2/7/EVENT: -COntext=1;
 TunnelID=20415: Processed StopCCN packet in Wait-connect state, and changed the tunnel state to Stopping.
*Jul  2 11:50:04:475 2019 H3C L2TPV2/7/EVENT: -COntext=1;
 TunnelID=20415: Delay-ACK timer expired, received duplicate Hello packet for 0 times and sent ZLB-ACK packet for 1 times. Ns=1, Nr=2.
*Jul  2 11:50:35:275 2019 H3C L2TPV2/7/EVENT: -COntext=1;
 TunnelID=20415: Delay-Cleanup timer expired and deleted the local tunnel.
粉丝:24人 关注:0人
试试debug ppp看看,l2tp这个内容比较少,隧道已经起来了没?
有隧道信息,但是状态位stopping,没有会话信息
黄健良 发表时间:2019-07-02
*Jul 2 11:50:04:239 2019 H3C L2TPV2/7/EVENT: -COntext=1; Parsed Result-Code AVP. Result-Code=2, Error-Code=0, Error-Message="". 这里的Result-Code=2, Error-Code=0,有解释吗,什么原因
黄健良 发表时间:2019-07-02
回复黄健良:
建议咨询一下400,这个报错是内部的模块
不科学君 发表时间:2019-07-02
