现在我登入后,帐号就只有这几个指令,也试过用CONSOLE线终端登入,在自检界面按<Ctrl+B>,进入BOOTROM的密码为空,在菜单后选7.并在系统提示时输入“Y”进行确认。回到BOOTROM菜单后,输入“0”。重启交换会跳过配置文件。直接登录交换机,但依旧只有以下几个指令,请问各位大神,有何方法拿得到超级密码或者方式还原交换机出厂值的。《Mac 地址 : 586AB194F925》
<H3C>?
User view commands:
initialize Delete the startup configuration file and reboot system
ipsetup Assign an IP address to VLAN-interface 1
password Specify password of local user
ping Ping function
quit Exit from current command view
reboot Reboot system/board/card
summary Display summary information of the device.
upgrade Upgrade the system boot file or the Boot ROM program
(0)
确定你的邮箱还未认证,请认证邮箱或绑定手机后进行当前操作
Please input BootRom password:******** Wrong password,Please input password again:******** Wrong password,Please input password again:******** Wrong password, system halt. 我在这里输入大写MOCEBNEF都无法登入。 请问以下,那个选项是恢复出厂设置的 BOOT MENU 1. Download application file to flash 2. Select application file to boot 3. Display all files in flash 4. Delete file from flash 5. Modify BootRom password 6. Enter BootRom upgrade menu 7. Skip current system configuration 8. Set BootRom password recovery 9. Set switch startup mode 0. Reboot Enter your choice(0-9):
