Port power enabled :enable
Port power ON/OFF :on
Port power status :Standard PD was detected
Port power mode :signal
Port PD class :0
port power priority :low
Port max power :15400 mW
Port current power :2400 mW
Port peak power :4100 mW
Port average power :2281 mW
Port current :50 mA
Port voltage :49 V
Port power enabled :enable Port power ON/OFF :on Port power status :Standard PD was detected Port power mode :signal Port PD class :0 port power priority :low Port max power :15400 mW Port current power :2400 mW Port peak power :4100 mW Port average power :2281 mW Port current :50 mA Port voltage :49 V
看不清楚,都是乱码
供电情况要怎么看,我这边看每个电口的供电的电流都不一样
你看看AP的功率是多少啊
Port average power :1704 mW
AP的型号是WA4320H-SI
用什么命令修改端口供电功率?
