查看接口信息,只能看到300s的流量,如果要进行监控,还是配合监控软件好,配置snmp,然后用监控软件,专业的用cacti,简单的用mrtg,prtg这些
(0)
查看300S 的接口流量信息是什么命令?show interface 吗
是的
[H3C]dis int Ethernet 0/0 Ethernet0/0 current state: UP Line protocol current state: UP Description: Ethernet0/0 Interface The Maximum Transmit Unit is 1500 Internet protocol processing : disabled IP Packet Frame Type: PKTFMT_ETHNT_2, Hardware Address: 3ce5-a6cf-42b5 IPv6 Packet Frame Type: PKTFMT_ETHNT_2, Hardware Address: 3ce5-a6cf-42b5 Media type is twisted pair, loopback not set, promiscuous mode not set 100Mb/s, Full-duplex, link type is autonegotiation Output flow-control is disabled, input flow-control is disabled Output queue : (Urgent queuing : Size/Length/Discards) 0/100/0 Output queue : (Protocol queuing : Size/Length/Discards) 0/500/0 Output queue : (FIFO queuing : Size/Length/Discards) 0/75/0 Last clearing of counters: Never Last 300 seconds input rate 990943.43 bytes/sec, 7927547 bits/sec, 916.88 packets/sec Last 300 seconds output rate 41514.19 bytes/sec, 332113 bits/sec, 503.35 packets/sec Input: 9003275 packets, 4197927015 bytes, 9003275 buffers 0 broadcasts, 1 multicasts, 0 pauses 0 errors, 0 runts, 0 giants 0 crc, 0 align errors, 0 overruns 0 dribbles, 0 drops, 0 no buffers Output:4386405 packets, 594884842 bytes, 4386405 buffers 8 broadcasts, 0 multicasts, 0 pauses 0 errors, 0 underruns, 0 collision
display int 接口号 华为的和华三的一样, cisco的 show int 接口号
(0)
确定你的邮箱还未认证,请认证邮箱或绑定手机后进行当前操作
show interface 看的是统计流量 我想看当前实时流量 您知道吗
display interface里有一个last 300秒的统计,可以全局下flow-intval 5改成5秒,就能看到5秒的实时流量了
