这是两台路由器的配置,各位大神能给指导指导吗?
站端
<zhanduan1>dis cu
version 5.20, Release 1508P02, Standard
sysname zhanduan1
clock timezone Beijing add 08:00:00
domain default enable system
router id 37.2.92.160
ip vpn-instance vpn-rt
route-distinguisher 23726:1
vpn-target 23726:101 export-extcommunity
vpn-target 23726:100 20000:100 30000:100 import-extcommunity
ip vpn-instance vpn-nrt
route-distinguisher 23726:2
vpn-target 23726:201 export-extcommunity
vpn-target 23726:200 20000:200 30000:200 import-extcommunity
ip vpn-instance vpn-pw
route-distinguisher 23726:4
vpn-target 23726:401 export-extcommunity
vpn-target 23726:400 import-extcommunity
vlan 1
vlan 10
description NMS
vlan 199
description To_vpn-rt
vlan 299
description To_vpn-nrt
vlan 499
description To_vpn-pw
mpls lsr-id 37.2.92.160
mpls
mpls ldp
domain system
access-limit disable
state active
idle-cut disable
self-service-url disable
local-user bzzdh
password cipher IV/L%>K11XF,YWX*NZ55OA!!
service-type ssh terminal
acl number 2000
rule 1 permit source 37.172.0.250 0
rule 2 permit source 37.172.0.200 0
rule 3 permit source 37.172.160.1 0
rule 5 deny
acl number 2001
acl number 3001
rule 0 deny tcp destination-port eq 135
rule 5 deny tcp destination-port eq 137
rule 10 deny tcp destination-port eq 138
rule 15 deny tcp destination-port eq 139
rule 20 deny tcp destination-port eq 445
rule 25 deny udp destination-port eq 135
rule 30 deny udp destination-port eq netbios-ns
rule 35 deny udp destination-port eq netbios-dgm
rule 40 deny udp destination-port eq netbios-ssn
rule 45 deny udp destination-port eq 445
interface Aux0
async mode flow
link-protocol ppp
interface Serial6/0
link-protocol ppp
interface Serial6/1
link-protocol ppp
interface Serial6/2
link-protocol ppp
interface Serial6/3
link-protocol ppp
interface NULL0
interface LoopBack0
ip address 37.2.92.160 255.255.255.255
interface GigabitEthernet0/0
port link-mode route
interface GigabitEthernet0/0.10
vlan-type dot1q vid 10
description To_NMS
ip address 37.172.160.30 255.255.255.240
interface GigabitEthernet0/0.199
vlan-type dot1q vid 199
description to vpn-rt
ip binding vpn-instance vpn-rt
ip address 37.173.160.126 255.255.255.128
interface GigabitEthernet0/0.299
vlan-type dot1q vid 299
description to vpn-nrt
ip binding vpn-instance vpn-nrt
ip address 37.174.160.126 255.255.255.128
interface GigabitEthernet0/1
ip address 37.172.160.2 255.255.255.252
ospf cost 10
mpls
mpls ldp
bgp 23726
undo synchronization
timer keepalive 5 hold 15
group hexin internal
peer hexin connect-interface LoopBack0
peer 37.2.92.170 group hexin
ipv4-family vpnv4
peer hexin enable
peer 37.2.92.170 enable
ipv4-family vpn-instance vpn-rt
import-route direct
ipv4-family vpn-instance vpn-nrt
import-route direct
ipv4-family vpn-instance vpn-pw
import-route direct
ospf 1
import-route direct
area 0.0.0.1
network 37.172.160.0 0.0.0.3
ip route-static 37.172.160.0 255.255.255.252 37.172.160.1
ip route-static 37.173.0.0 255.255.0.0 37.172.160.1
ip route-static 37.174.0.0 255.255.0.0 37.172.160.1
ssh server enable
user-interface con 0
user-interface aux 0
user-interface vty 0 4
acl 2000 inbound
authentication-mode scheme
idle-timeout 5 0
protocol inbound ssh
return
核心
<hexin>dis cu
sysname hexin
router id 37.2.92.170
vpn-target 23726:100 20000:100 30000:100 export-extcommunity
vpn-target 23726:101 23726:100 30000:100 20000:100 import-extcommunity
vlan 1
vlan 10
description NMS
vlan 199
vlan 299
vlan 499
mpls lsr-id 37.2.92.170
mpls
mpls ldp
domain system
state active
idle-cut disable
local-user admin
password cipher H;-]Ma5VSZD=`&4T-(O7UH*2_*aAEH84Z7W/O2`\89H>(,<4Z,BO&L"TX$_S#6.NM(0=0\)*5WWQ=^Q`MAF4<1!!
service-type telnet
local-user bzzdh
acl number 2000
rule 5 deny
acl number 2001
acl number 3001
interface Aux0
async mode flow
link-protocol ppp
interface Serial6/0
link-protocol ppp
interface Serial6/1
link-protocol ppp
interface Serial6/2
link-protocol ppp
interface Serial6/3
link-protocol ppp
interface NULL0
interface LoopBack0
ip address 37.2.92.170 255.255.255.255
description To_NMS
ip address 37.172.170.30 255.255.255.240
description vpn-rt
ip address 37.173.170.126 255.255.255.128
description vpn-nrt
ip address 37.174.92.126 255.255.255.128
description to zhuanduan1
ip address 37.172.160.1 255.255.255.252
ospf cost 10
bgp 23726
group zhanduan1 internal
peer zhanduan1 connect-interface LoopBack0
peer 37.2.92.160 group zhanduan1
ipv4-family vpnv4
peer zhanduan1 enable
peer zhanduan1 route-policy Deny-DD-Sum-Pri export
peer 37.2.92.160 enable
import-route direct
import-route direct
ospf 1
import-route direct
area 0.0.0.1
description to zhanduan
ip route-static 37.173.0.0 255.255.0.0 37.172.160.2
ip route-static 37.173.160.0 255.255.255.0 37.172.160.2
ip route-static 37.174.0.0 255.255.0.0 37.172.160.2
idle-timeout 5 0
acl 2000 inbound
idle-timeout 5 0
return
<hexin>ping -vpn-instance vpn-rt 37.173.170.2
PING 37.173.170.2: 56 data bytes, press CTRL_C to break
Reply from 37.173.170.2: bytes=56 Sequence=1 ttl=128 time=1 ms
Reply from 37.173.170.2: bytes=56 Sequence=2 ttl=128 time=1 ms
Reply from 37.173.170.2: bytes=56 Sequence=3 ttl=128 time=1 ms
Reply from 37.173.170.2: bytes=56 Sequence=4 ttl=128 time=1 ms
Reply from 37.173.170.2: bytes=56 Sequence=5 ttl=128 time=1 ms
--- 37.173.170.2 ping statistics ---
5 packet(s) transmitted
5 packet(s) received
0.00% packet loss
round-trip min/avg/max = 1/1/1 ms
<hexin>ping -vpn-instance vpn-rt 37.173.160.126
PING 37.173.160.126: 56 data bytes, press CTRL_C to break
Request time out
Request time out
Request time out
Request time out
Request time out
(0)
确定你的邮箱还未认证,请认证邮箱或绑定手机后进行当前操作
Bgp 和ospf都建立了啊。
没注意到你把直连宣告到OSPF,BGP确实能起来.但是你的MPLS,起不来,你上面的配置就没使能
