终端上线正常,能ping sslvpn网关,内部地址不能访问,报错如下
*Sep 11 18:18:51:695 2019 ZCB-INT-F1030 SSLVPNK/7/SSLVPN_ERROR: -COntext=1; IPAC: Failed to get peer data. *Sep 11 18:19:01:694 2019 ZCB-INT-F1030 SSLVPNK/7/SSLVPN_ERROR: -COntext=1; IPAC: Failed to find peer 224.0.0.5 in VPN instance 0. *Sep 11 18:19:01:694 2019 ZCB-INT-F1030 SSLVPNK/7/SSLVPN_ERROR: -COntext=1; IPAC: Failed to get peer data. *Sep 11 18:19:11:694 2019 ZCB-INT-F1030 SSLVPNK/7/SSLVPN_ERROR: -COntext=1; IPAC: Failed to find peer 224.0.0.5 in VPN instance 0. *Sep 11 18:19:11:694 2019 ZCB-INT-F1030 SSLVPNK/7/SSLVPN_ERROR: -COntext=1; IPAC: Failed to get peer data. *Sep 11 18:19:21:694 2019 ZCB-INT-F1030 SSLVPNK/7/SSLVPN_ERROR: -COntext=1; IPAC: Failed to find peer 224.0.0.5 in VPN instance 0.
(0)
确定你的邮箱还未认证,请认证邮箱或绑定手机后进行当前操作
都能上线正常了,
这个报错很明显就不是安全策略的问题
