如何将WAP712c-LI切换成胖ap,这个ap是云ap,跟普通的不太一样
2019-09-12提问
  • 1收藏,2427浏览
粉丝:18人 关注:1人
如标题
粉丝:6人 关注:3人
1.1.1  bootware下进行升级
  1. 在设备重启过程中按ctrl+B键,进入bootware
  2. 依次按照如下步骤进行升级
首先选3,进入以太菜单
接着,选5进入ftp或者tftp,配置ftp或者tftp服务器,拷贝版本
下一步,选2,更新主版本文件
接下来,版本解压完成后,退回到主菜单,并重启设备,即可完成版本更新
BootWare Validating...
Press Ctrl+B to access EXTENDED-BOOTWARE MENU...
Password recovery capability is enabled.
Note: The current operating device is flash
Enter < Storage Device Operation > to select device.
==========================<EXTENDED-BOOTWARE MENU>==========================
|<1> Boot System                                                           |
|<2> Enter Serial SubMenu                                                  |
|<3> Enter Ethernet SubMenu                                                |
|<4> File Control                                                          |
|<5> Restore to Factory Default Configuration                              |
|<6> Skip Current System Configuration                                     |
|<7> BootWare Operation Menu                                               |
|<8> Skip Authentication for Console Login                                 |
|<9> Storage Device Operation                                              |
|<0> Reboot        |
Ctrl+Z: Access EXTENDED ASSISTANT MENU
Ctrl+F: Format File System
Ctrl+C: Display Copyright
Ctrl+Y: Change AP Mode
Enter your choice(0-9): 3
==========================<Enter Ethernet SubMenu>==========================
|Note:the operating device is flash                                        |
|<1> Download Image Program To SDRAM And Run                               |
|<2> Update Main Image File                                                |
|<3> Update Backup Image File                                              |
|<4> Download Files(*.*)                                                   |
|<5> Modify Ethernet Parameter                                             |
|<0> Exit To Main Menu                                                     |
|<Ensure The Parameter Be Modified Before Downloading!>                    |
Enter your choice(0-5): 5
==========================<ETHERNET PARAMETER SET>==========================
|Note:       '.' = Clear field.                                            |
|            '-' = Go to previous field.                                   |
|         Ctrl+D = Quit.                                                   |
Protocol (FTP or TFTP) :ftp    -------------------------------选择通过ftp或者tftp拷贝版本,本例选择ftp
Load File Name         :wa5300-fat.ipe------------------要拷贝的版本名字
Target File Name       :wa5300-fat.ipe  -------------------拷贝到设备上后的文件命名,可根据需要修改
Server IP Address      :5.0.0.157 5.0.0.184    --------ftp server的地址
Local IP Address       :105.1.108.152 5.0.0.157 ------------设备ip地址
Subnet Mask            :0
Gateway IP Address     :0
FTP User Name          :123 123           ---------------------ftp 用户名
FTP User Password      :****** ******    --------------------ftp密码
Enter your choice(0-5): 2
Loading.....................................................................
.............................................................Done.
40704000 bytes downloaded!
The file is exist,will you overwrite it? [Y/N]Y
Image file wa5300-fat-boot.bin is self-decompressing...
Saving file flash:/wa5300-fat-boot.bin ..............................Done.
Image file wa5300-fat-system.bin is self-decompressing...
Saving file flash:/wa5300-fat-system.bin ...................................
Enter your choice(0-5):       0
|<1> Boot System                                                           |
|<4> File Control                                                          |
|<0> Reboot        |
Enter your choice(0-9): 0
System is starting...
Press Ctrl+D to access BASIC-BOOTWARE MENU
Booting Normal Extended BootWare
好像不对吧,听说是要升级boot的版本
zhiliao_mlw0U 发表时间:2019-09-12
回复zhiliao_mlw0U:
操作参考案例:https://zhiliao.h3c.com/Theme/details/71191
非同小可 发表时间:2019-09-12
