在日志中类似这样的输出,默认都没显示,有什么命令开启吗?
%%10ARP/5/ARP_DUPLICATE_IPADDR_DETECT(l): Detected an IP address conflict. The device with MAC address xxxx-xxxx-xxxx connected to GigabitEthernet1/0/x in VLAN x and the device with MAC address xxxx-xxxx-xxxx connected to GigabitEthernet1/0/x in VLAN x are using the same IP address x.x.x.x
目前info-center已经做了如下配置,还是没有显示 ,版本为:H3C Comware Software, Version 7.1.070, Release 7536P05
[system]dis cu | in info
info-center loghost x.x.x.x facility local0
info-center source default console level informational
info-center source default monitor level informational
info-center source default loghost deny
info-center source ARP loghost level informational
info-center source IPADDR loghost level informational
[system]dis info-center
Information Center: Enabled
Console: Enabled
Monitor: Enabled
Log host: Enabled x.x.x.x,
port number: 514,
host facility: local0
Log buffer: Enabled
Max buffer size 1024, current buffer size 512 Current messages 512, dropped messages 0, overwritten messages 1605 Log file: Enabled
Security log file: Disabled Information timestamp format: Log host: Date Other output destination: Date
(0)
确定你的邮箱还未认证,请认证邮箱或绑定手机后进行当前操作
logbuffer里也没有。
