请教一下,我不太懂网络配置,能否详细写出配置,含路由怎么写这样的配置。谢谢!
(0)
假设7506与12508之间的路由协议运行OSPF,7506与12508的互联地址段为10.0.0.0/30,7506与下联交换机互联才用trunk
1、7506配置如下:
[S7506]vlan 10
[S7506-vlan10]quit
[S7506]vlan 20
[S7506-vlan20]quit
[S7506]vlan 45
[S7506-vlan45]quit
[S7506]vlan 46
[S7506-vlan46]quit
[S7506]int vlan 10
[S7506-Vlan-interface10]ip address 192.168.10.254 24
[S7506-Vlan-interface10]quit
[S7506]int vlan 20
[S7506-Vlan-interface20]ip address 192.168.20.254 24
[S7506-Vlan-interface20]quit
[S7506]int vlan 45
[S7506-Vlan-interface45]ip address 10.65.45.254 24
[S7506-Vlan-interface45]quit
[S7506]int vlan 46
[S7506-Vlan-interface46]ip address 10.65.46.254 24
[S7506-Vlan-interface46]quit
[S7506]int ran gi 1/0/3 to gi 1/0/7
[S7506-if-range]po li tr
[S7506-if-range]undo po tr pe vlan 1
[S7506-if-range]po tr pe vlan 10 20 45 46
[S7506-if-range]quit
[S7506]int Route-Aggregation 1
[S7506-Route-Aggregation1]ip address 10.0.0.1 30
[S7506-Route-Aggregation1]quit
[S7506]int ran gi 1/0/1 to gi 1/0/2
[S7506-if-range]port link-mode route
[S7506-if-range]port link-aggregation group 1
[S7506]ospf 1
[S7506-ospf-1]area 0.0.0.0
[S7506-ospf-1-area-0.0.0.0]network 10.0.0.1 0.0.0.0
[S7506-ospf-1-area-0.0.0.0]network 192.168.10.0 0.0.0.255
[S7506-ospf-1-area-0.0.0.0]network 192.168.20.0 0.0.0.255
[S7506-ospf-1-area-0.0.0.0]network 10.65.45.0 0.0.0.255
[S7506-ospf-1-area-0.0.0.0]network 10.65.46.0 0.0.0.255
[S7506-ospf-1-area-0.0.0.0]quit
[S7506-ospf-1]quit
[S7506]
12508配置:
[12508]int Route-Aggregation 1
[12508-Route-Aggregation1]ip address 10.0.0.2 30
[12508-Route-Aggregation1]quit
[12508]int range GigabitEthernet 1/0/1 to gi 1/0/2
[12508-if-range]port link-mode route
[12508-if-range]port link-aggregation group 1
[12508-if-range]quit
[12508]ospf 1
[12508-ospf-1]area 0.0.0.0
[12508-ospf-1-area-0.0.0.0]network 10.0.0.2 0.0.0.0
[12508-ospf-1-area-0.0.0.0]quit
[12508-ospf-1]quit
测试情况:
[12508]dis ospf peer
OSPF Process 1 with Router ID 10.0.0.2 Neighbor Brief Information Area: 0.0.0.0 Router ID Address Pri Dead-Time State Interface 192.168.20.254 10.0.0.1 1 31 Full/DR RAGG1
[12508]dis ip routing-table
Destinations : 16 Routes : 16 Destination/Mask Proto Pre Cost NextHop Interface 0.0.0.0/32 Direct 0 0 127.0.0.1 InLoop0 10.0.0.0/30 Direct 0 0 10.0.0.2 RAGG1 10.0.0.0/32 Direct 0 0 10.0.0.2 RAGG1 10.0.0.2/32 Direct 0 0 127.0.0.1 InLoop0 10.0.0.3/32 Direct 0 0 10.0.0.2 RAGG1 10.65.45.0/24 O_INTRA 10 2 10.0.0.1 RAGG1 10.65.46.0/24 O_INTRA 10 2 10.0.0.1 RAGG1 127.0.0.0/8 Direct 0 0 127.0.0.1 InLoop0 127.0.0.0/32 Direct 0 0 127.0.0.1 InLoop0 127.0.0.1/32 Direct 0 0 127.0.0.1 InLoop0 127.255.255.255/32 Direct 0 0 127.0.0.1 InLoop0 192.168.10.0/24 O_INTRA 10 2 10.0.0.1 RAGG1 192.168.20.0/24 O_INTRA 10 2 10.0.0.1 RAGG1 224.0.0.0/4 Direct 0 0 0.0.0.0 NULL0 224.0.0.0/24 Direct 0 0 0.0.0.0 NULL0 255.255.255.255/32 Direct 0 0 127.0.0.1 InLoop0 [12508]
(0)
其他交换机不做配置意思是其他的您会配置还是说空配置运行?现在哪个设备不会配置?
(0)
DIY-s5120设备空配置,这四台设备就是接入pc终端的, 目前S7506上建了vlan 864 vlan 接口下写有10.65.46.254 10.65.45.254 sub 主要就是接入交换机上把端口划入vlan 864 上行接口per vlan 864 不理解的是四台设备都划入864吗?那其它地址不通啊!
目前S7506上建了vlan 864
10.65.45.254 sub
(0)
确定你的邮箱还未认证,请认证邮箱或绑定手机后进行当前操作
基本清楚了,感谢!
感谢支持,望关注
