h3c f100 c ei型号防火墙下面服务器带宽只有50兆,配置有什么问题么?
  • 1收藏,1275浏览
在h3c f100 c ei型号防火墙下面有十多台180段的服务器,防火墙外面是其他段的地址,现在外面服务器从180段的服务器上拷贝大文件只有5兆所有的速度,对应50兆的带宽。 其他段互相拷贝大文件都能达到100兆带宽。 测试发现是这台防火墙出现的问题。请问这台防火墙上有没有限制其他网段对180网段速度的限制? 配置文件有没有限制带宽的策略?
<f100-c>dis cu
# sysname f100-c
 # undo firewall packet-filter enable
 firewall packet-filter default permit
# insulate
# undo firewall statistic system enable
#  server-type extended
# domain system
# local-user admin password simple hytera service-type telnet terminal level 3 service-type ftp
# acl number 2000 rule 0 permit source 10.0.2.0 0.0.0.255
 # acl number 3000
 rule 0 deny ip destination 192.168.0.0 0.0.255.255
 rule 100 deny ip destination 70.70.1.0 0.0.0.255
 rule 101 deny ip destination 20.190.0.0 0.0.255.255
 rule 102 permit ip
 # interface Aux0 async mode flow
 # interface Ethernet0/0
 description toDIP ip address 10.110.36.251 255.255.255.0
 nat outbound 3000
 nat server protocol tcp global 10.110.36.251 33898 inside 20.180.5.80 22
 nat server protocol tcp global 10.110.36.251 33899 inside 20.180.0.88 22
nat server protocol tcp global 10.110.36.251 33893 inside 20.180.0.63 ftp
nat server protocol tcp global 10.110.36.251 33892 inside 20.180.0.62 ftp
nat server protocol udp global 10.110.36.251 33893 inside 20.180.0.63 22
nat server protocol tcp global 10.110.36.251 5067 inside 20.180.0.62 5067
nat server protocol udp global 10.110.36.251 5067 inside 20.180.0.62 5067
 nat server protocol tcp global 10.110.36.251 46000 inside 20.180.0.60 46000
nat server protocol tcp global 10.110.36.251 46001 inside 20.180.0.60 46001
nat server protocol tcp global 10.110.36.251 8050 inside 20.180.0.65 8050
nat server protocol tcp global 10.110.36.251 9010 inside 20.180.0.62 9010
nat server protocol tcp global 10.110.36.251 8040 inside 20.180.0.66 8040
 nat server protocol tcp global 10.110.36.251 33891 inside 20.180.0.89 3688
nat server protocol udp global 10.110.36.251 20100 inside 20.180.0.63 20100
nat server protocol udp global 10.110.36.251 20101 inside 20.180.0.63 20101
 nat server protocol udp global 10.110.36.251 20102 inside 20.180.0.63 20102
nat server protocol udp global 10.110.36.251 20103 inside 20.180.0.63 20103
nat server protocol udp global 10.110.36.251 20104 inside 20.180.0.63 20104
nat server protocol udp global 10.110.36.251 20105 inside 20.180.0.63 20105
nat server protocol udp global 10.110.36.251 20106 inside 20.180.0.63 20106
nat server protocol udp global 10.110.36.251 20107 inside 20.180.0.63 20107
nat server protocol udp global 10.110.36.251 20108 inside 20.180.0.63 20108
nat server protocol udp global 10.110.36.251 20109 inside 20.180.0.63 20109
nat server protocol udp global 10.110.36.251 20110 inside 20.180.0.63 20110
nat server protocol udp global 10.110.36.251 20111 inside 20.180.0.63 20111
nat server protocol udp global 10.110.36.251 20112 inside 20.180.0.63 20112
nat server protocol udp global 10.110.36.251 20113 inside 20.180.0.63 20113
nat server protocol udp global 10.110.36.251 20114 inside 20.180.0.63 20114
nat server protocol udp global 10.110.36.251 20115 inside 20.180.0.63 20115
nat server protocol udp global 10.110.36.251 20116 inside 20.180.0.63 20116
nat server protocol udp global 10.110.36.251 20117 inside 20.180.0.63 20117
nat server protocol udp global 10.110.36.251 20118 inside 20.180.0.63 20118
nat server protocol udp global 10.110.36.251 20119 inside 20.180.0.63 20119
nat server protocol udp global 10.110.36.251 20120 inside 20.180.0.63 20120
nat server protocol udp global 10.110.36.251 20121 inside 20.180.0.63 20121
nat server protocol udp global 10.110.36.251 20122 inside 20.180.0.63 20122
nat server protocol udp global 10.110.36.251 20123 inside 20.180.0.63 20123
nat server protocol udp global 10.110.36.251 20124 inside 20.180.0.63 20124
nat server protocol udp global 10.110.36.251 20125 inside 20.180.0.63 20125
 nat server protocol udp global 10.110.36.251 20126 inside 20.180.0.63 20126
nat server protocol udp global 10.110.36.251 20127 inside 20.180.0.63 20127
nat server protocol udp global 10.110.36.251 20128 inside 20.180.0.63 20128
nat server protocol udp global 10.110.36.251 20129 inside 20.180.0.63 20129
 nat server protocol udp global 10.110.36.251 20130 inside 20.180.0.63 20130
nat server protocol udp global 10.110.36.251 20131 inside 20.180.0.63 20131
nat server protocol udp global 10.110.36.251 20132 inside 20.180.0.63 20132
nat server protocol udp global 10.110.36.251 20133 inside 20.180.0.63 20133
 nat server protocol udp global 10.110.36.251 20134 inside 20.180.0.63 20134
nat server protocol udp global 10.110.36.251 20135 inside 20.180.0.63 20135
nat server protocol udp global 10.110.36.251 20136 inside 20.180.0.63 20136
nat server protocol udp global 10.110.36.251 20137 inside 20.180.0.63 20137
 nat server protocol udp global 10.110.36.251 20138 inside 20.180.0.63 20138
nat server protocol udp global 10.110.36.251 20139 inside 20.180.0.63 20139
 nat server protocol udp global 10.110.36.251 20140 inside 20.180.0.63 20140
nat server protocol udp global 10.110.36.251 20141 inside 20.180.0.63 20141
 nat server protocol udp global 10.110.36.251 20142 inside 20.180.0.63 20142
nat server protocol udp global 10.110.36.251 20143 inside 20.180.0.63 20143
nat server protocol udp global 10.110.36.251 20144 inside 20.180.0.63 20144
nat server protocol udp global 10.110.36.251 20145 inside 20.180.0.63 20145
nat server protocol udp global 10.110.36.251 20146 inside 20.180.0.63 20146
nat server protocol udp global 10.110.36.251 20147 inside 20.180.0.63 20147
nat server protocol udp global 10.110.36.251 20148 inside 20.180.0.63 20148
 nat server protocol udp global 10.110.36.251 20149 inside 20.180.0.63 20149
 nat server protocol udp global 10.110.36.251 20150 inside 20.180.0.63 20150
 nat server protocol udp global 10.110.36.251 20151 inside 20.180.0.63 20151
nat server protocol udp global 10.110.36.251 20152 inside 20.180.0.63 20152
nat server protocol udp global 10.110.36.251 20153 inside 20.180.0.63 20153
nat server protocol udp global 10.110.36.251 20154 inside 20.180.0.63 20154
nat server protocol udp global 10.110.36.251 20155 inside 20.180.0.63 20155
nat server protocol udp global 10.110.36.251 20156 inside 20.180.0.63 20156
 nat server protocol udp global 10.110.36.251 20157 inside 20.180.0.63 20157
 nat server protocol udp global 10.110.36.251 20158 inside 20.180.0.63 20158
nat server protocol udp global 10.110.36.251 20159 inside 20.180.0.63 20159
nat server protocol udp global 10.110.36.251 20160 inside 20.180.0.63 20160
nat server protocol udp global 10.110.36.251 20161 inside 20.180.0.63 20161
nat server protocol udp global 10.110.36.251 20162 inside 20.180.0.63 20162
 nat server protocol udp global 10.110.36.251 20163 inside 20.180.0.63 20163
 nat server protocol udp global 10.110.36.251 20164 inside 20.180.0.63 20164
nat server protocol udp global 10.110.36.251 20165 inside 20.180.0.63 20165
nat server protocol udp global 10.110.36.251 20166 inside 20.180.0.63 20166
nat server protocol udp global 10.110.36.251 20167 inside 20.180.0.63 20167
nat server protocol udp global 10.110.36.251 20168 inside 20.180.0.63 20168
nat server protocol udp global 10.110.36.251 20169 inside 20.180.0.63 20169
nat server protocol udp global 10.110.36.251 20170 inside 20.180.0.63 20170
nat server protocol udp global 10.110.36.251 20171 inside 20.180.0.63 20171
nat server protocol udp global 10.110.36.251 20172 inside 20.180.0.63 20172
nat server protocol udp global 10.110.36.251 20173 inside 20.180.0.63 20173
nat server protocol udp global 10.110.36.251 20174 inside 20.180.0.63 20174
nat server protocol udp global 10.110.36.251 20175 inside 20.180.0.63 20175
 nat server protocol udp global 10.110.36.251 20176 inside 20.180.0.63 20176
nat server protocol udp global 10.110.36.251 20177 inside 20.180.0.63 20177
nat server protocol udp global 10.110.36.251 20178 inside 20.180.0.63 20178
nat server protocol udp global 10.110.36.251 20179 inside 20.180.0.63 20179
nat server protocol udp global 10.110.36.251 20180 inside 20.180.0.63 20180
nat server protocol udp global 10.110.36.251 20181 inside 20.180.0.63 20181
 nat server protocol udp global 10.110.36.251 20182 inside 20.180.0.63 20182
nat server protocol udp global 10.110.36.251 20183 inside 20.180.0.63 20183
nat server protocol udp global 10.110.36.251 20184 inside 20.180.0.63 20184
nat server protocol udp global 10.110.36.251 20185 inside 20.180.0.63 20185
nat server protocol udp global 10.110.36.251 20186 inside 20.180.0.63 20186
 nat server protocol udp global 10.110.36.251 20187 inside 20.180.0.63 20187
nat server protocol udp global 10.110.36.251 20188 inside 20.180.0.63 20188
nat server protocol udp global 10.110.36.251 20189 inside 20.180.0.63 20189
nat server protocol udp global 10.110.36.251 20190 inside 20.180.0.63 20190
nat server protocol udp global 10.110.36.251 20191 inside 20.180.0.63 20191
nat server protocol udp global 10.110.36.251 20192 inside 20.180.0.63 20192
nat server protocol udp global 10.110.36.251 20193 inside 20.180.0.63 20193
nat server protocol udp global 10.110.36.251 20194 inside 20.180.0.63 20194
nat server protocol udp global 10.110.36.251 20195 inside 20.180.0.63 20195
nat server protocol udp global 10.110.36.251 20196 inside 20.180.0.63 20196
nat server protocol udp global 10.110.36.251 20197 inside 20.180.0.63 20197
nat server protocol udp global 10.110.36.251 20198 inside 20.180.0.63 20198
nat server protocol udp global 10.110.36.251 20199 inside 20.180.0.63 20199
 nat server protocol tcp global 10.110.36.251 40001 inside 20.180.0.31 22
nat server protocol tcp global 10.110.36.251 40002 inside 20.180.0.33 22
nat server protocol tcp global 10.110.36.251 33894 inside 20.180.0.63 3688
nat server protocol tcp global 10.110.36.251 33897 inside 20.180.0.62 22
# interface Ethernet0/1 ip address 20.180.0.2 255.255.255.0
 # interface Ethernet0/2 ip address 20.180.4.2 255.255.255.0
 # interface Ethernet0/3 description toMPT ip address 10.0.4.1 255.255.255.0
 # interface Ethernet0/4 description toSW1/0/47 ip address 20.1.1.6 255.255.255.252
 # interface Encrypt1/0
 # interface Tunnel100 ip address 20.181.0.1 255.255.255.0 source 10.110.36.251 destination 10.110.36.252
 # interface NULL0
 # interface LoopBack1 ip address 20.0.3.247 255.255.255.255
 # firewall zone local set priority 100
 # firewall zone trust
 add interface Ethernet0/2
 add interface Ethernet0/4
 set priority 85
 # firewall zone untrust set priority 5
 # firewall zone DMZ
 add interface Ethernet0/0
 add interface Ethernet0/1
 add interface Ethernet0/3
 set priority 50
 # firewall interzone local trust
 # firewall interzone local untrust
 # firewall interzone local DMZ
 # firewall interzone trust untrust
 # firewall interzone trust DMZ
 # firewall interzone DMZ untrust
 # info-center source default channel 2 debug state on info-center loghost 192.168.69.14 facility local5
# FTP server enable
 # ip route-static 0.0.0.0 0.0.0.0 10.110.36.1 preference 60
 ip route-static 20.180.0.0 255.255.0.0 20.180.0.1 preference 60
 ip route-static 20.180.1.0 255.255.255.0 20.180.4.1 preference 60
 ip route-static 20.180.2.0 255.255.255.0 20.180.4.1 preference 60
 ip route-static 20.180.3.0 255.255.255.0 20.180.4.1 preference 60
 ip route-static 20.180.5.0 255.255.255.0 20.180.4.1 preference 60
 ip route-static 20.190.0.0 255.255.0.0 10.110.36.252 preference 60
 ip route-static 40.18.8.0 255.255.255.0 10.110.36.100 preference 60
 ip route-static 40.19.8.0 255.255.255.0 10.110.36.100 preference 60
 ip route-static 70.70.1.0 255.255.255.0 10.110.36.29 preference 60
 # snmp-agent snmp-agent local-engineid 000063A27F00000100001515 snmp-agent community read public snmp-agent sys-info version all
 # user-interface con 0 user-interface aux 0 user-interface vty 0 4 authentication-mode
 # return
粉丝:21人 关注:0人
配置没什么问题,不是最新版本升级一下。还不行的话建议打400问下吧。
防火墙比较老,序列号过期了,还能打进400么?
zhiliao_O0U4v 发表时间:2019-11-04
