5530AP恢复出厂设置,除了按键还有其他命令可以实现吗?
2019-11-09提问
  • 1收藏,1045浏览
粉丝:124人 关注:6人
还可以通过console进入设备去清空配置,具体操作如下:
1、使用reset saved-configuration 命令清空配置,然后设备会提示您是否确定清空配置,选择Y
<1>reset saved-configuration
The saved configuration file will be erased. Are you sure? [Y/N]:y
Configuration file in flash: is being cleared. Please wait ... Configuration file is cleared.
2、使用reboot重启设备,设备会提示是否继续重启,选择Y
<1>reboot
Start to check configuration with next startup configuration file, please wait.........DONE! This command will reboot the device. Continue? [Y/N]:y
 Now rebooting, please wait... %Nov 9 21:32:04:822 2019 1 DEV/5/SYSTEM_REBOOT: System is rebooting now.
粉丝:15人 关注:0人
console接入进入命令行
<H3C>reset saved-configuration
 <H3C>reboot  //先选N不保存配置,再选Y确认重启
