Management network interface: vswitch0
Management ip address: 172.16.4.1
\n================
1. Check System:\n================
Check System:stop h3class all services
Stopping http Service... DONE
Stopping heartbeat Service... DONE
Stopping dhcp Service... DONE
Stopping queue Service... DONE
FAIL
[m
Reason: /var/lib/h3class/venv/horizon is existing. Please delete it manually before installing a new h3class.
The detailed installation log could be found in /tmp/h3class_installation.log
[m
Management network interface: vswitch0 Management ip address: 172.16.4.1 \n================ 1. Check System:\n================ Check System:stop h3class all services Stopping http Service... DONE Stopping heartbeat Service... DONE Stopping dhcp Service... DONE Stopping queue Service... DONE FAIL [m Reason: /var/lib/h3class/venv/horizon is existing. Please delete it manually before installing a new h3class. The detailed installation log could be found in /tmp/h3class_installation.log [m
以上为报错信息
报错就是文件已存在,建议打800处理吧
