WAP712c-fit 删除bin文件后怎么办
2020-01-07提问
  • 1收藏,942浏览
WAP712c-fit 删除bin文件后怎么办?现在只能进CTRL+D   和  CTRL+B     菜单
粉丝:39人 关注:3人
CTRL+B    重新导入版本
1. 使用Console口登入到命令行,从官网下载软件版本,
2. 电脑网卡设置为:192.168.0.1 255.255.255.0,如下例子打开TFTP服务器,把软件版本放到电脑桌面上,TFTP服务器目录指向电脑桌面,然后点击确定
3. AP重启的时候按住Ctrl+B进入设备的bootroom菜单
===============<EXTEND-BOOTWARE MENU>=========================
|<1> Boot System
|<2> Enter Serial SubMenu
|<3> Enter Ethernet SubMenu
|<4> File Control
|<5> Restore to Factory Default Configuration
|<6> Skip Current System Configuration
|<7> BootWare Operation Menu
|<8> Clear Super Password
|<9> Storage Device Operation
|<0> Reboot
Ctrl+C: Display Copyright
Ctrl+F: Format File System
Enter your choice(0-9): Ctrl+F
y
Enter your choice(0-9): 3(此处输入)
================<Enter Ethernet SubMenu>==========================
|Note:the operating device is flash
|<1> Download Application Program To SDRAM And Run
|<2> Update Main Application File
|<3> Update Backup Application File
|<4> Update Secure Application File
|<5> Modify Ethernet Parameter
|<0> Exit To Main Menu
|<Ensure The Parameter Be Modified Before Downloading!>
4. 进入修改以太网参数菜单,使用TFTP网络协议传输到AP
Enter your choice(0-5): 5
===========<ETHERNET PARAMETER SET>=====================
|Note:       "." = Clear field.
|            "-" = Go to previous field.
|          Ctrl+D = Quit.
Protocol (FTP or TFTP) : TFTP
//忽略输出内容,直接输入TFTP,然后回车
Load File Name         :wa4300s_fit.bin
Target File Name       :wa4300s_fit.bin
Server IP Address      :192.168.0.1
//忽略输出内容,直接输入电脑主机的 IP,比如192.168.0.1,然后回车
Local IP Address       :192.168.0.50
//忽略输出内容,直接输入和电脑主机的ip同一网段,比如192.168.0.50,然后回车
Gateway IP Address     :0.0.0.0
//忽略输出内容,直接回车
备注:注意给电脑手动配置一个与AP同网段的IP地址,保证电脑与AP路由可达
Enter your choice(0-5): 2   //此时可以看到TFTP服务器上数据上传的滚动
Loading.....................................................................
....................................Done!
5. 返回主菜单,查看设备上是否真的已经上传了该软件版本
=================<Enter Ethernet SubMenu>==========================
Enter your choice(0-5): 0
6. 返回主菜单,将设备进行重启
<1> Display All File(s)
<2> Set Application File type
<3> Delete File
Enter your choice(0-3): 0
==================<EXTEND-BOOTWARE MENU>===========================
<1> Boot System
<4> File Control
<0>Reboot        ==================================================================
Enter your choice(0-9): 0
System is starting...
SMSAMA 八段
粉丝:15人 关注:8人
通过ctrl+B可以重新导入版本
zhiliao_24055 知了小白
从那个子菜单重新导入 ??
3
Johnny囧尼 发表时间:2020-01-07
