iMC7.1+inode客户端
2020-01-08提问
  • 1收藏,1215浏览
问题总结如下:
1、win10电脑上所有安装inode客户端都是提示状态“不需要安全检查”,在win7、win8系统上是提示状态"安全"。
2、接入设备Radius配置方案为扩展类型
radius scheme system
 server-type extended
 primary authentication 10.99.X.X key cipher $c$3$ne+PJegNyQt9cp8yJ0YItE+G1vdLfQ==
 primary accounting 10.99.X.X key cipher $c$3$+N8JbmsR5XJNzIuMZcXH94uNGmbxaQ==
 secondary authentication 10.99.X.X key cipher $c$3$aYASYwXld+slAFIVKQLEPyzhTo0jng==
 secondary accounting 10.99.X.X key cipher $c$3$8BQV7L4Nb3fNvTiUt2xtKMf7LLCPAw==
 user-name-format without-domain
domain system
 authentication lan-access radius-scheme system
 authorization lan-access radius-scheme system
 accounting lan-access radius-scheme system
 access-limit disable
 state active
 idle-cut disable
 self-service-url disable
 accounting optional
3、802.1x认证选择eap模式部署。
4、接入设备版本信息
<BBN-MCCBG-5120-B>display  version
H3C Comware Platform Software
Comware Software, Version 5.20, Release 1518P02
Copyright (c) 2004-2016 Hangzhou H3C Tech. Co., Ltd. All rights reserved.
H3C S5120S-28P-EI uptime is 150 weeks, 1 day, 0 hour, 9 minutes
H3C S5120S-28P-EI
128M    bytes DRAM
128M    bytes Nand Flash Memory
Config Register points to Nand Flash
Hardware Version is REV.B
CPLD Version is 002
Bootrom Version is 178
[SubSlot 0] 24GE+4SFP Hardware Version is REV.B
5、imc版本信息如图所示
6、inode客户端版本信息如图所示
粉丝:11人 关注:2人
是同一个账号吗?要不要安全检查跟配置的接入服务有关,另外,看看win10的客户端是否定制了安全检查功能
