wx3540e断电重启后配置被清空
2020-01-13提问
  • 1收藏,831浏览
***************************************************************************** * Copyright (c) 2004-2015 Hangzhou H3C Tech. Co., Ltd. All rights reserved. * * Without the owner's prior written consent, * * no decompiling or reverse-engineering shall be allowed. * ****************************************************************************** User interface con0 is available. Please press ENTER. Please set your country/region code. Input ? to get the country code list, or input q to log out. CN <H3C> #Jan 13 05:07:16:515 2020 H3C SHELL/4/LOGIN: Trap 1.3.6.1.4.1.2011.10.2.2.1.1.3.0.1<h3cLogIn>: login from Console %Jan 13 05:07:16:535 2020 H3C SHELL/5/SHELL_LOGIN: Console logged in from con0. <H3C> <H3C>disp curr # version 5.20, Release 3709P48 # sysname H3C # domain default enable system # telnet server enable # port-security enable # password-recovery enable # vlan 1 # domain system access-limit disable state active idle-cut disable self-service-url disable # user-group system group-attribute allow-guest # local-user admin password cipher $c$3$AomUGp2VJ/GuXCJ80kI5gTYWq+7t28ZB authorization-attribute level 3 service-type telnet # wlan rrm dot11a mandatory-rate 6 12 24 dot11a supported-rate 9 18 36 48 54 dot11b mandatory-rate 1 2 dot11b supported-rate 5.5 11 dot11g mandatory-rate 1 2 5.5 11 dot11g supported-rate 6 9 12 18 24 36 48 54 # wlan ap-group default_group # interface NULL0 # interface Vlan-interface1 ip address 192.168.0.100 255.255.255.0 # interface GigabitEthernet1/0/1 # interface GigabitEthernet1/0/2 # interface GigabitEthernet1/0/3 # interface GigabitEthernet1/0/4 # interface Ten-GigabitEthernet1/0/5 # wlan ips malformed-detect-policy default signature deauth_flood signature-id 1 signature broadcast_deauth_flood signature-id 2 signature disassoc_flood signature-id 3 signature broadcast_disassoc_flood signature-id 4 signature eapol_logoff_flood signature-id 5 signature eap_success_flood signature-id 6 signature eap_failure_flood signature-id 7 signature pspoll_flood signature-id 8 signature cts_flood signature-id 9 signature rts_flood signature-id 10 signature addba_req_flood signature-id 11 signature-policy default countermeasure-policy default attack-detect-policy default virtual-security-domain default attack-detect-policy default malformed-detect-policy default signature-policy default countermeasure-policy default # undo info-center logfile enable # user-interface con 0 user-interface vty 0 4 authentication-mode scheme user privilege level 3 # return
以上是笔记本直连后显示的配置情况,目前是ap没有信号,手机搜索不到,怎么能恢复到正常的状态,谢谢!新手求教!
SMSAMA 八段
粉丝:15人 关注:8人
有没有之前的配置文件? 如果没有的话,你就只能手动重新写配置了
zhiliao_rihmfX 知了小白
之前的配置没导出来,重新写的话麻烦不哦
