BOOT MENU 1. Download application file to flash 2. Select application file to boot 3. Display all files in flash 4. Delete file from flash 5. Restore to factory default configuration 6. Enter BootRom upgrade menu 7. Skip current system configuration 8. Reserved 9. Set switch startup mode 0. Reboot Ctrl+F: Format File System Ctrl+P: Skip Super Password Ctrl+R: Download application to SDRAM and Run Ctrl+Z: Access EXTEND-ASSISTANT MENU Ctrl+C: Display Copyright Enter your choice(0-9): 0 Starting...... Press Ctrl+D to access BASIC BOOT MENU Press Ctrl+T to start memory test ************************************************************************ * * * H3C S3100V2-26TP-EI BOOTROM, Version 118 * * * ************************************************************************ Copyright (c) 2004-2012 Hangzhou H3C Technologies Co., Ltd. Creation Date : Dec 27 2012,11:50:32 CPU Clock Speed : 200MHz Memory Size : 128MB Flash Size : 16MB CPLD Version : NULL PCB Version : Ver.A Mac Address : 586AB17E4F33 Application program does not exist. BootRom password: Not required. Please press Enter to continue. Password recovery capability is enabled. BOOT MENU 1. Download application file to flash 2. Select application file to boot 3. Display all files in flash 4. Delete file from flash 5. Restore to factory default configuration 6. Enter BootRom upgrade menu 7. Skip current system configuration 8. Reserved 9. Set switch startup mode 0. Reboot Ctrl+F: Format File System Ctrl+P: Skip Super Password Ctrl+R: Download application to SDRAM and Run Ctrl+Z: Access EXTEND-ASSISTANT MENU Ctrl+C: Display Copyright Enter your choice(0-9): BOOT MENU 1. Download application file to flash 2. Select application file to boot 3. Display all files in flash 4. Delete file from flash 5. Restore to factory default configuration 6. Enter BootRom upgrade menu 7. Skip current system configuration 8. Reserved 9. Set switch startup mode 0. Reboot Ctrl+F: Format File System Ctrl+P: Skip Super Password Ctrl+R: Download application to SDRAM and Run
对对对
(0)
是否我下载的最新版本,跨版本了,好不容易用console线传上去了,但是没有升级啊,好像就卡死了一样。。。。format flash之后重新弄也是一样。。。求解。。
S3100V2_E-CMW520-R5213P08.bin,这个是我下载的~~~
现在的bootrom版本是
Display all file(s) in flash: File Number File Size(bytes) File Name =============================================================================== Free space: 15343616 bytes The current application file is S3100V2_E-CMW520-R5203P05.bin (*)-with main attribute (b)-with backup attribute (*b)-with both main and backup attribute
(0)
上传到设备上的版本大小和下载的大小一样吗?现在升级成功了吗?没成功的话留个远程方式我给你远程看看。
确定你的邮箱还未认证,请认证邮箱或绑定手机后进行当前操作
怎么升级呢,我敲了6,接着设置了3,用了115200速率,最后传上文件了,但是没有然后了。。
敲2选择版本启动,如果还是不行的话建议打400看下,这里面看的比较费劲。
过保了啊,400不给解决,才跑来这里的,我们是银行的,下次给领导说,不买h3c了,要知道,我们至少买了上万台啊,气死我了
可以找当地办事处的售后工程师看下的。
过年啦,估计没人了,小县城啊,只是地方银行,全系列h3c
