S5560S如何连接电信光猫上网
2020-03-05提问
  • 1收藏,1127浏览
粉丝:1人 关注:1人
如下图,上游为电信光猫,PC 自动分配ip地址可以上网:
IP:192.168.30.107
掩码: 255.255.255.0
网关: 192.168.30.1
DNS:192.168.30.1
现需要接 S5560S 的三层交换机,
期初路由配置为:ip route-static 0.0.0.0 0 Vlan-interface30 192.168.30.107
端口 1-16 接的pc 无法上网。
又静态路由改为 ip route-static 0.0.0.0 0 Vlan-interface30 192.168.30.1
PC 重新获取IP信息,还是无法上网,pc 可以获取到 vlan 10  或者 vlan 20 的IP地址,但是 pc无法ping通 192.168.30.1
S5560S 配置窗口里是可以 ping通 192.168.30.1
配置如下:
  [NEO]dis cu
 version 7.1.070, Release 6126P20
 sysname NEO
 irf mac-address persistent timer
 irf auto-update enable
 undo irf link-delay
 irf member 1 priority 1
 dhcp enable
 lldp global enable
 password-recovery enable
vlan 1
vlan 10
vlan 20
vlan 30
 stp global enable
dhcp server ip-pool 10
 gateway-list 192.168.10.1
 network 192.168.10.0 mask 255.255.255.0
 dns-list  192.168.30.1
dhcp server ip-pool 20
 gateway-list 192.168.20.1
 network 192.168.20.0 mask 255.255.255.0
interface NULL0
interface Vlan-interface10
 ip address 192.168.10.1 255.255.255.0
interface Vlan-interface20
 ip address 192.168.20.1 255.255.255.0
interface Vlan-interface30
 ip address 192.168.30.107 255.255.255.0
interface GigabitEthernet1/0/1
 port access vlan 10
interface GigabitEthernet1/0/2
 port access vlan 10
interface GigabitEthernet1/0/3
 port access vlan 10
interface GigabitEthernet1/0/4
 port access vlan 10
interface GigabitEthernet1/0/5
 port access vlan 10
interface GigabitEthernet1/0/6
 port access vlan 10
interface GigabitEthernet1/0/7
 port access vlan 10
interface GigabitEthernet1/0/8
 port access vlan 10
interface GigabitEthernet1/0/9
 port access vlan 20
interface GigabitEthernet1/0/10
 port access vlan 20
interface GigabitEthernet1/0/11
 port access vlan 20
interface GigabitEthernet1/0/12
 port access vlan 20
interface GigabitEthernet1/0/13
 port access vlan 20
interface GigabitEthernet1/0/14
 port access vlan 20
interface GigabitEthernet1/0/15
 port access vlan 20
interface GigabitEthernet1/0/16
 port access vlan 20
interface GigabitEthernet1/0/17
 port access vlan 30
interface GigabitEthernet1/0/18
 port access vlan 30
interface GigabitEthernet1/0/19
 port access vlan 30
interface GigabitEthernet1/0/20
 port access vlan 30
interface GigabitEthernet1/0/21
 port access vlan 30
interface GigabitEthernet1/0/22
 port access vlan 30
interface GigabitEthernet1/0/23
 port access vlan 30
interface GigabitEthernet1/0/24
 port access vlan 30
interface GigabitEthernet1/0/25
interface GigabitEthernet1/0/26
interface GigabitEthernet1/0/27
interface GigabitEthernet1/0/28
 scheduler logfile size 16
line class aux
 user-role network-admin
line class vty
 user-role network-operator
line aux 0
line vty 0 63
acl number 3000
radius scheme system
 user-name-format without-domain
domain system
 domain default enable system
role name level-0
 description Predefined level-0 role
role name level-1
 description Predefined level-1 role
role name level-2
 description Predefined level-2 role
role name level-3
 description Predefined level-3 role
role name level-4
 description Predefined level-4 role
role name level-5
 description Predefined level-5 role
role name level-6
 description Predefined level-6 role
role name level-7
 description Predefined level-7 role
role name level-8
 description Predefined level-8 role
role name level-9
 description Predefined level-9 role
role name level-10
 description Predefined level-10 role
role name level-11
 description Predefined level-11 role
role name level-12
 description Predefined level-12 role
role name level-13
 description Predefined level-13 role
role name level-14
 description Predefined level-14 role
user-group system
return
粉丝:6人 关注:3人
光猫上没有配置回程路由指向10和20网段
光猫没有配置静态路由的功能
烟花里的尘埃 发表时间:2020-03-05
那就没法实现,除非光猫下面接路由器
非同小可 发表时间:2020-03-05
那就没法实现,除非光猫下面接路由器
确实是缺少回程路由,测试过在HCL上搭配 路由器才行
