AC WX2540E 不通过SSID不同VLAN问题
2020-03-17提问
  • 1收藏,891浏览
如题,两个业务VLAN,VLAN8,VLAN9,客户端连接上VLAN8可以获取到正确IP,VLAN9获取的不对,麻烦帮忙看看配置哪里出问题
单独的DHCP提供地址服务
AC-SW-AP
#AC配置
 vlan4
vlan8
vlan9
vlan100
 interface WLAN-ESS1
 port link-type hybrid
 undo port hybrid vlan 1
 port hybrid vlan 4 untagged
 port hybrid pvid vlan 4
 mac-vlan enable
 port-security
port-mode psk
 port-security tx-key-type 11key
 port-security preshared-key pass-phrase qqqqqqqq
mac-vlan enable
 interface WLAN-ESS2
 mac-vlan enable
 port-security
port-mode
psk port-security tx-key-type 11key
mac-vlan enable
 wlan service-template 1
 crypto ssid VLAN8
 bind WLAN-ESS 1
 cipher-suite ccmp
 security-ie rsn
 security-ie wpa
 client forwarding-mode local vlan 8
 key-derivation sha256
 service-template enable
 wlan service-template 2
crypto ssid VLAN9
 bind WLAN-ESS 2
 cipher-suite ccmp
 security-ie rsn
 security-ie wpa
 client forwarding-mode local vlan 9
 wlan ap apauto model WA2620-AGN
 map-configuration officecfg.txt
serial-id auto
 radio 1
 service-template 1 vlan-id 8
service-template 2 vlan-id 9
 radio enable
 radio 2
 radio enable
 ip route-static 0.0.0.0 0.0.0.0 172.18.24.1
interface Vlan-interface100
 ip address 172.18.24.10 255.255.255.0
 interface GigabitEthernet1/0/4
 port link-mode bridge
 port link-type trunk
 port trunk permit vlan 1 8 to 9 12 to 13 100
 port trunk pvid vlan 100
 #交换机配置
#接AP
interface GigabitEthernet1/0/13
 undo port trunk permit vlan 1
 port trunk permit vlan 8 to 9 100
接AC
interface GigabitEthernet1/0/23
 #下发AC的配置文件
vlan 9
 vlan 8
 interface GigabitEthernet 1/0/1
 port trunk permit vlan 100 8 9
粉丝:6人 关注:5人
配置不对劲啊,无线模板下 绑定了WLAN-ESS1 口,WLAN-ESS1 下绑定vlan或者设置哪些vlan不打标记通过,但你在无线模板下“client forwarding-mode local vlan 9 ”这个命令和WLAN-ESS1接口下的 port hybrid vlan 4 untagged不一致啊,建议做如下调整:
1,interface WLAN-ESS2
 port hybrid vlan 4 9 untagged
2, wlan service-template 2
      undo service-template en
     service-template en
3,设置好vlan的地址池
谢谢 修改了现在正常了
愚钝无知 发表时间:2020-03-17
回复愚钝无知:
请您点个采纳呀
聆听聆听 发表时间:2020-03-17
回复聆听聆听:
昨晚用手机测试客户端登录,客户端可以正常获取到两个VLAN的地址,今天用笔记本,笔记本只能获取到VLAN8的,VLAN9的就时获取不到
愚钝无知 发表时间:2020-03-18
回复聆听聆听:
手机端没有任何问题,就时笔记本获取不到
粉丝:3人 关注:0人
可以手动配置地址连接VLAN 9无线信号,排查链路问题还是dhcp问题
地址池确认没问题 不采用本地转发 客户端信息正常
配置一个vlan 9 的ip地址连接那个无线测试
巡山的小妖 发表时间:2020-03-17
