AC(MSG360-10)最近老是死机,ap掉线,日志文件,求问和这个有关没,需要怎么设置
2020-03-26提问
  • 1收藏,2290浏览
轻风 零段
System stratum changed from 16 to 3 after clock update.
2020-03-26 20:09:32
通知
System Leap Indicator changed from 3 to 0 after clock update.
2020-03-26 20:09:32
通知
Lost synchronization with NTP server with IP address 116.203.151.74.
2020-03-26 20:09:31
通知
admin logged in from 192.168.8.187
2020-03-26 20:05:03
警告
-User=-IPAddr=; Command return in view shell failed to be matched.
2020-03-26 20:03:59
警告
CAPWAP tunnel to AP zz went down. Reason: Processed join request in Run state.
2020-03-26 20:02:18
警告
CAPWAP tunnel to AP sg went down. Reason: Processed join request in Run state.
2020-03-26 20:02:17
通知
System stratum changed from 2 to 3 after clock update.
2020-03-26 20:02:17
警告
CAPWAP tunnel to AP rens went down. Reason: Processed join request in Run state.
2020-03-26 20:02:14
警告
CAPWAP tunnel to AP dhys went down. Reason: Processed join request in Run state.
2020-03-26 20:02:14
警告
CAPWAP tunnel to AP hmen went down. Reason: Processed join request in Run state.
2020-03-26 20:02:09
警告
CAPWAP tunnel to AP xhys went down. Reason: Processed join request in Run state.
2020-03-26 20:02:09
通知
2020-03-26 20:01:15
通知
System stratum changed from 4 to 2 after clock update.
2020-03-26 19:57:16
通知
2020-03-26 19:55:35
通知
System stratum changed from 3 to 4 after clock update.
2020-03-26 19:54:47
通知
2020-03-26 19:50:19
通知
2020-03-26 19:48:05
通知
2020-03-26 19:47:50
通知
2020-03-26 19:38:00
通知
System stratum changed from 3 to 2 after clock update.
2020-03-26 19:35:38
skylar 九段
粉丝:42人 关注:0人
看日志ap有经常掉线的情况,有可能是接口频繁up down导致
System stratum changed from 3 to 2 after clock update. 2020-03-26 19:35:38 这个系统跳转特别多需要怎么处理啊?
轻风 发表时间:2020-03-26
会不会是这个造成的?
轻风 发表时间:2020-03-26
这个是通知级别的,应该不影响业务
skylar 发表时间:2020-03-27
这个能是怎么造成这个通知的啊,需要怎么设置正确才不会通知了?
轻风 发表时间:2020-03-27
轻风 知了小白
2020-03-26 19:35:38
这个系统跳转特别多需要怎么处理啊?
