5120作为核心交换与路由器连接为24口,级联IP为192.168.254.253
vlan1:为1-4口,地址为192.168.88.0 vlan2:为5-12,地址为192.168.89.0 vlan3:为13-23口地址为192.168.90.1
vlan1,vlan2是内网,vlan3是外网,VLAN1与VLAN2互相访问,VLAN1与VLAN3隔离互不访问,VLAN2与VLAN2隔离互不访问
(0)
根据您提出的需求,有如下的配置过程,请参考:
1、创建VLAN:
vlan 2
vlan 3
2、将VLAN划分到接口:
int range gi 1/0/1 to gi 1/0/4
port link-type access
port access vlan 1
int range gi 1/0/5 to gi 1/0/12
port access vlan 2
int range gi 1/0/13 to gi 1/0/23
port access vlan 3
3、给VLAN设置IP地址:
int vlan 1
ip address 192.168.88.1 24
int vlan 2
ip address 192.168.89.1 24
int vlan 3
ip address 192.168.90.1 24
4、配置5120与路由器的互联及路由指向:
int gi 1/0/24
port link-mode route
ip address 192.168.254.253 24
ip route-static 0.0.0.0 0.0.0.0 192.169.254.254 //由于不明确路由器的接口地址,因此临时使用192.168.254.254
5、配置ACL,实现不能互访:
acl number 3000
rule 0 deny ip source 192.168.88.0 0.0.0.255 destination 192.168.90.0 0.0.0.255
rule 1 deny ip source 192.168.89.0 0.0.0.255 destination 192.168.90.0 0.0.0.255
rule 2 permit ip source any destination any
int vlan 2
packet-filter 3000 inbound
int vlan 3
以上为配置过程,仅供参考,实际配置请以现场情况为准,请悉知!
(2)
举例:不让1.1.1.1和1.1.2.1以及 1.1.3.1网段互访
[H3C]acl number 2000
[H3C-acl-basic-2000]rule 0 deny source 1.1.1.1 0.0.0.255
[H3C-acl-basic-2000]rule 5 deny source 1.1.2.1 0.0.0.255
[H3C-acl-basic-2000]rule 10 permit
[H3C]int Vlan-interface 3
[H3C-Vlan-interface3]packet-filter 2000 outbound
[H3C]acl number 2002
[H3C-acl-basic-2000]rule 5 deny source 1.1.3.1 0.0.0.255
[H3C]int Vlan-interface 2
[H3C-Vlan-interface2]packet-filter 2000 outbound
[H3C]acl number 2001
[H3C-acl-basic-2000]rule 0 deny source 1.1.3.1 0.0.0.255
[H3C]int Vlan-interface 1
[H3C-Vlan-interface1]packet-filter 2002 outbound
(0)
确定你的邮箱还未认证,请认证邮箱或绑定手机后进行当前操作
