Comware V7使用***.***认证的问题
2018-03-07提问
  • 1收藏,1991浏览
各位大神是否使用过***.***作为comware v7设备的aaa服务器,在***.***的authorization.xml文件中应该如何下发login用户的角色权限。我在配置文档里看到“HWTACACS 服务器上的授权角色配置必须满足格式:roles="name1 name2 namen",具体在authorization.xml文件中应该如何写呢??本人的配置如下:
- <Authorization> - <!-- This entry will only be processed in the times given below  --> - <!-- <Time>MTWRFSN,04:00-21:00</Time>  --> - <!-- This authorization section applies to the following user groups. In case of conflicting authorization entries for the same group, the entry which appears first in the file is used.  --> - <UserGroups>   <UserGroup>Network Engineering</UserGroup>   </UserGroups> - <!-- This authorization section applies to the following client groups. In case of conflicting authorization entries for the same client group, the entry which appears first in the file is used.  --> - <!-- If no client groups are specified then the settings are applied to the specified usergroups irrespective of the clients they come from  --> - <ClientGroups>   <ClientGroup>H3C-Comware7</ClientGroup>   </ClientGroups> - <AutoExec>   <Set>shell:roles=network-admin</Set>   </AutoExec> - <Shell> - <!-- note that the login and exit commands are always permitted  -->   <Permit>.*</Permit> - <!-- This will allow all show commands   -->   <Deny>.*</Deny> - <!-- This will deny all other commands   -->   </Shell>   </Authorization>
这个真么配置过,但是一般tacacs认证服务器上下发权限需要写level-15,你试试。
粉丝:3人 关注:0人
这个没有配置过
