POE交换机报错
2020-04-13提问
  • 1收藏,4496浏览
粉丝:6人 关注:5人
交换机型号:S5130S-28S-PWR-HI
连接AP型号:WA5530
所连AP数量:19
现在出现AP无规律重启显现,查看AP诊断信息得知:
*** Boot History(Startup Time and Reason) ***
2020-02-14 12:39:47 Power on
交换机诊断信息报了这么一条错误:
%Apr 6 23:23:07:930 2020 PAN_PCR_T.SCR13_H3C5130S_01 IFNET/3/PHY_UPDOWN: Physical state on the interface GigabitEthernet1/0/21 changed to up.
%Apr 6 23:23:07:931 2020 PAN_PCR_T.SCR13_H3C5130S_01 IFNET/5/LINK_UPDOWN: Line protocol state on the interface GigabitEthernet1/0/21 changed to up.
%Apr 6 23:23:54:026 2020 PAN_PCR_T.SCR13_H3C5130S_01 POE/1/PSE_PORT_ON_OFF_CHANGE: Trap <pethPsePortOnOffNotification>: PSE 4, IfIndex 20, Detection Status 3.
尤其这条“PSE 4, IfIndex 20, Detection Status 3.”是什么意思,
究竟是AP重启导致的交换机端口UP/DOWN,还是交换机端口UP/DOWN导致的AP 重启 ?
粉丝:111人 关注:1人
我看下线路下面是否存在错误包
<PAN_PCR_T.SCR13_H3C5130S_01>dis int g1/0/21 GigabitEthernet1/0/21 Current state: UP Line protocol state: UP IP packet frame type: Ethernet II, hardware address: 441a-fa4a-649a Description: GigabitEthernet1/0/21 Interface Bandwidth: 1000000 kbps Loopback is not set Media type is twisted pair Port hardware type is 1000_BASE_T 1000Mbps-speed mode, full-duplex mode Link speed type is autonegotiation, link duplex type is autonegotiation Flow-control is not enabled Maximum frame length: 10240 Allow jumbo frames to pass Broadcast max-ratio: 100% Multicast max-ratio: 100% Unicast max-ratio: 100% PVID: 3420 MDI type: Automdix Port link-type: Trunk VLAN Passing: 3420, 3450, 3460, 3501-3616 VLAN permitted: 3420, 3450, 3460, 3501-3616 Trunk port encapsulation: IEEE 802.1q Port priority: 0 Last link flapping: 6 days 15 hours 52 minutes Last clearing of counters: Never Peak input rate: 1390829 bytes/sec, at 2020-03-06 12:41:24 Peak output rate: 2248000 bytes/sec, at 2020-02-14 16:40:53 Last 300 second input: 3 packets/sec 635 bytes/sec 0% Last 300 second output: 108 packets/sec 13427 bytes/sec 0% Input (total): 218454417 packets, 38742579000 bytes 217334769 unicasts, 190260 broadcasts, 929388 multicasts, 0 pauses Input (normal): 218454417 packets, - bytes 217334769 unicasts, 190260 broadcasts, 929388 multicasts, 0 pauses Input: 0 input errors, 0 runts, 0 giants, 0 throttles 0 CRC, 0 frame, - overruns, 0 aborts - ignored, - parity errors Output (total): 2491808569 packets, 1556918986648 bytes 132164019 unicasts, 396827916 broadcasts, 1962816634 multicasts, 0 pauses Output (normal): 2491808569 packets, - bytes 132164019 unicasts, 396827916 broadcasts, 1962816634 multicasts, 0 pauses Output: 0 output errors, - underruns, - buffer failures 0 aborts, 0 deferred, 0 collisions, 0 late collisions 0 lost carrier, - no carrier 没有错误包
聆听聆听 发表时间:2020-04-13
设备版本是哪一个,如果之前是好,突然出现。一般是诱发了什么BUG
漓离原上谱 发表时间:2020-04-13
lumm 九段
粉丝:20人 关注:5人
端口21,开始供电,接口up了就开始供电了,
