堆叠怎么配置?
2020-04-22提问
  • 1收藏,1250浏览
堆叠怎么配置?
粉丝:121人 关注:6人
由于型号不明确,因此临时给出S5820的堆叠配置过程及案例链接:
假设有两台S5820进行堆叠
1、1号设备关键配置如下:
[H3C]irf member 1 renumber 1     //将1号设备设定为成员1
Renumbering the member ID may result in configuration change or loss. Continue?[Y/N]:y
[H3C]int range Ten-GigabitEthernet 1/0/50 to Ten-GigabitEthernet 1/0/51
[H3C-if-range]shutdown
[H3C-if-range]quit
[H3C]irf-port 1/1  //将物理端口绑定到IRF端口
[H3C-irf-port1/1]port group interface Ten-GigabitEthernet 1/0/50
[H3C-irf-port1/1]port group interface Ten-GigabitEthernet 1/0/51
[H3C-irf-port1/1]quit
[H3C-if-range]undo shutdown
[H3C-if-range]quit
[H3C]irf-port-configuration active  //激活IRF
[H3C]save
2、2号设备关键配置点如下:
[H3C]irf member 1 renumber 2  //将2号设备设定为成员2
[H3C-if-range]quit
[H3C]irf-port 1/2  //将物理端口绑定到IRF端口
[H3C-irf-port1/2]port group interface Ten-GigabitEthernet 1/0/50
[H3C-irf-port1/2]port group interface Ten-GigabitEthernet 1/0/51
[H3C-irf-port1/2]quit
[H3C-if-range]quit
[H3C]save
3、分别将成员1设备、成员2设备重启
4、测试
<H3C>dis irf  //查看IRF的信息,看到成员1和成员2的设备信息都在一起
MemberID    Role    Priority  CPU-Mac         Description
 *+1        Master  1         30bd-490a-0104  ---
   2        Standby 1         30bd-525e-0204  ---
 The bridge MAC of the IRF is: 30bd-490a-0100
 Auto upgrade                : yes
 Mac persistent              : 6 min
 Domain ID                   : 0
<H3C>
<H3C>dis irf link  //查看成员1、成员2 IRF链路的状态均为UP
Member 1
 IRF Port  Interface                             Status
 1         Ten-GigabitEthernet1/0/50             UP
           Ten-GigabitEthernet1/0/51             UP
 2         disable                               --
Member 2
 1         disable                               --
 2         Ten-GigabitEthernet2/0/50             UP
           Ten-GigabitEthernet2/0/51             UP
<H3C>
<H3C>dis irf configuration  //查看IRF的配置信息
 MemberID NewID    IRF-Port1                     IRF-Port2
 1        1        Ten-GigabitEthernet1/0/50     disable
 2        2        disable                       Ten-GigabitEthernet2/0/50
<H3C>
<H3C>dis irf topology  //查看IRF的拓扑信息
                              Topology Info
               IRF-Port1                IRF-Port2
 MemberID    Link       neighbor      Link       neighbor    Belong To
 2           DIS        ---           UP         1           30bd-490a-0104
 1           UP         2             DIS        ---         30bd-490a-0104
<H3C>
具体的案例链接如下:
https://zhiliao.h3c.com/theme/details/96463
清堂 二段
粉丝:7人 关注:0人
什么设备,可以参考:
http://www.h3c.com/cn/d_201911/1242546_30005_0.htm#_Toc23519394
粉丝:3人 关注:0人
没有型号就先发个交换机的吧:
配置需求或说明
1.1 适用产品系列
      本案例适用于如S5120-52P-LI、S5120-28P-SI、S5120-48P-EI等S5120系列的交换机。
1.2 配置需求及实现的效果
     由于网络规模迅速扩大,当前中心交换机(Device A)转发能力已经不能满足需求,需要另外增加一台设备Device B。现需要将两台设备配置IRF2堆叠,将网络转发能力提高一倍,并实现网络易管理、易维护。Device A和Device B分别使用自带的两个万兆口做堆叠口。也可以只用一个接口堆叠,根据实际情况而定。
组网图
配置步骤
配置步骤
3.1 配置IRF2
3.1.1 配置设备编号
# Device A保留缺省编号为1,不需要进行配置。同时,在Device B上将设备的成员编号修改为2。
[DeviceB] irf member 1 renumber 2
Warning: Renumbering the switch number may result in configuration change or loss. Continue? [Y/N]:y
[DeviceB]
3.1.2 配置堆叠口
#将两台设备断电后,按组网图所示连接IRF链路,然后将两台设备上电。在Device A上创建设备的IRF端口2,与物理端口Ten-GigabitEthernet1/0/25、 Ten-GigabitEthernet1/0/26绑定,并保存配置。
[DeviceA] interface ten-gigabitethernet 1/0/25
[DeviceA-Ten-GigabitEthernet1/0/25] shutdown
[DeviceA-Ten-GigabitEthernet1/0/25] quit
[DeviceA] interface ten-gigabitethernet 1/0/26
[DeviceA-Ten-GigabitEthernet1/0/26] shutdown
[DeviceA-Ten-GigabitEthernet1/0/26] quit
[DeviceA] irf-port 1/2
[DeviceA-irf-port1/2] port group interface ten-gigabitethernet1/0/25
[DeviceA-irf-port1/2] port group interface ten-gigabitethernet1/0/26
[DeviceA-irf-port1/2] quit
[DeviceA-Ten-GigabitEthernet1/0/25] undo shutdown
[DeviceA-Ten-GigabitEthernet1/0/26] undo shutdown
[DeviceA] save force
# 在Device B上创建设备的IRF端口1,与物理端口Ten-GigabitEthernet2/0/25、Ten-GigabitEthernet2/0/26绑定,并保存配置。
[DeviceB] interface ten-gigabitethernet 2/0/25
[DeviceB-Ten-GigabitEthernet2/0/25] shutdown
[DeviceB-Ten-GigabitEthernet2/0/25] quit
[DeviceB] interface ten-gigabitethernet 2/0/26
[DeviceB-Ten-GigabitEthernet2/0/26] shutdown
[DeviceB-Ten-GigabitEthernet2/0/26] quit
[DeviceB] irf-port 2/1
[DeviceB-irf-port2/1] port group interface ten-gigabitethernet2/0/25
[DeviceB-irf-port2/1] port group interface ten-gigabitethernet2/0/26
[DeviceB-irf-port2/1] quit
[DeviceB-Ten-GigabitEthernet2/0/25] undo shutdown
[DeviceB-Ten-GigabitEthernet2/0/26] undo shutdown
[DeviceB] save force
# 激活DeviceA的IRF端口配置。
[DeviceA] irf-port-configuration active
# 激活DeviceB的IRF端口配置。
[DeviceB] irf-port-configuration active
#两台设备间将会进行Master竞选,竞选失败的一方将自动重启,重启完成后,IRF形成,系统名称统一为DeviceA
3.2 BFD分裂检测(选配)
IRF设备一旦分裂,会变成两台配置完全相同的设备,导致业务转发有问题。为了避免此类问题出现,可以配置分裂检测。设备一旦检测到IRF2分裂,则自动关闭备设备的所有非保留端口。在此介绍BFD MAD分裂检测配置方法。使用网线Device A上的端口GigabitEthernet1/0/1和Device B上的端口GigabitEthernet2/0/1连接起来。
# 创建VLAN 3,并将Device A上的端口GigabitEthernet1/0/1和Device B上的端口GigabitEthernet2/0/1加入VLAN中。
[DeviceA] vlan 3
[DeviceA-vlan3] port gigabitethernet 1/0/1 gigabitethernet 2/0/1
[DeviceA-vlan3] quit
# 创建VLAN接口3,并配置MAD IP地址。
[DeviceA] interface vlan-interface 3
[DeviceA-Vlan-interface3] mad bfd enable
[DeviceA-Vlan-interface3] mad ip address 192.168.2.1 24 member 1
[DeviceA-Vlan-interface3] mad ip address 192.168.2.2 24 member 2
[DeviceA-Vlan-interface3] quit
# 按组网图所示连接BFD MAD链路。
# 因为BFD MAD和生成树功能互斥,所以在GigabitEthernet1/0/1和GigabitEthernet2/0/1上关闭生成树协议。
[DeviceA] interface gigabitethernet 1/0/1
[DeviceA-Gigabitethernet1/0/1] undo stp enable
[DeviceA-Gigabitethernet1/0/1] quit
[DeviceA] interface gigabitethernet 2/0/1
[DeviceA-Gigabitethernet2/0/1] undo stp enable
