交换机+网络不稳定查看log发现lldp报错
2018-03-12提问
  • 1收藏,12117浏览
汇聚交换机提示
%May 23 01:33:03:534 2013 APGJZX-S5560 LLDP/6/LLDP_CREATE_NEIGHBOR: Nearest bridge agent neighbor created on port GigabitEthernet1/0/2 (IfIndex 2), neighbor's chassis ID is 84d9-3149-7060, port ID is GigabitEthernet1/0/25. %May 23 01:33:04:884 2013 APGJZX-S5560 LLDP/5/LLDP_NEIGHBOR_AGE_OUT: Nearest bridge agent neighbor aged out on port GigabitEthernet1/0/17 (IfIndex 17), neighbor's chassis ID is 9428-2e3c-1e50, port ID is Ten-GigabitEthernet1/0/25. %May 23 01:33:41:481 2013 APGJZX-S5560 LLDP/6/LLDP_CREATE_NEIGHBOR: Nearest bridge agent neighbor created on port GigabitEthernet1/0/18 (IfIndex 18), neighbor's chassis ID is 487a-da2a-3c3e, port ID is GigabitEthernet1/0/25. %May 23 01:33:58:619 2013 APGJZX-S5560 LLDP/6/LLDP_CREATE_NEIGHBOR: Nearest bridge agent neighbor created on port GigabitEthernet1/0/3 (IfIndex 3), neighbor's chassis ID is 9428-2e3c-4448, port ID is Ten-GigabitEthernet1/0/25. %May 23 01:34:33:288 2013 APGJZX-S5560 LLDP/6/LLDP_CREATE_NEIGHBOR: Nearest bridge agent neighbor created on port GigabitEthernet1/0/17 (IfIndex 17), neighbor's chassis ID is 9428-2e3c-1e50, port ID is Ten-GigabitEthernet1/0/25. %May 23 01:34:36:924 2013 APGJZX-S5560 LLDP/6/LLDP_CREATE_NEIGHBOR: Nearest bridge agent neighbor created on port GigabitEthernet1/0/4 (IfIndex 4), neighbor's chassis ID is 9428-2e3c-4178, port ID is Ten-GigabitEthernet1/0/25. %May 23 01:36:41:884 2013 APGJZX-S5560 LLDP/5/LLDP_NEIGHBOR_AGE_OUT: Nearest bridge agent neighbor aged out on port GigabitEthernet1/0/18 (IfIndex 18), neighbor's chassis ID is 487a-da2a-3c3e, port ID is GigabitEthernet1/0/25.
汇聚交换机二层组网,网管在核心
lemon 四段
看下接口有没有up/down,接口down排查一下这几个接口,换线换接口试一下;接口状态正常,看下这个接口是否有CRC错包记录,看看是否有连接跳线架、光电转换之类的。
端口没有up/dowwn crc也没有错误
zhiliao_a8gDs 发表时间:2018-03-12
建议通过debug或者抓包看看lldp交互
zhiliao_susuqtt 发表时间:2018-03-13
粉丝:52人 关注:4人
互联都是啥设备呀,光口互联还是电口互联?还是要从链路层去处理排查下这个问题,有没有可能有环路。
