SecPath F100-S-G 防火墙端口映射
2018-03-14提问
  • 1收藏,2235浏览
我想映射我的3389端口,映射完但是不通,请指教。下面是我的防火墙配置。
sysname FIRWALLF100-M
super password level 3 simple 123456
firewall packet-filter enable
firewall packet-filter default permit
firewall statistic system enable
pki entity svpndefent
common-name svpn-gw
organization-unit security
organization h3c
locality beijing
state beijing
country cn
pki domain default
crl check disable
pki domain svpndefdom
ca identifier svpn
certificate request entity svpndefent
crl check disable
radius scheme system
server-type extended
domain system
local-user admin
password simple 123456
service-type ssh telnet
level 3
local-user jqict
password cipher BC)Q_@WF*X05R02O"V$J0!!!
service-type ssh
level 3
acl number 2000
rule 0 permit source 192.168.0.0 0.0.15.255
rule 1 deny
acl number 3000
rule 0 permit ip source 58.18.89.206 0 destination 192.168.0.250 0
acl number 3002
description WCN_ACL_WAN_IN
rule 0 deny tcp destination-port range 6881 6890
rule 0 comment wcn_BT
rule 1 deny tcp destination-port range 81 82
rule 1 comment wcn_BT
rule 2 deny tcp destination-port eq 6969
rule 2 comment wcn_BT
rule 4 deny tcp destination-port eq 2710
rule 4 comment wcn_BT
rule 5 deny tcp destination-port range 4661 4662
rule 5 comment wcn_Emule
rule 6 deny udp destination-port eq 6656
rule 6 comment wcn_Emule
rule 7 deny udp destination-port eq 4672
rule 7 comment wcn_Emule
rule 37 deny tcp destination-port eq 445
rule 37 comment wcn_network_virus
rule 38 deny udp destination-port eq 445
rule 38 comment wcn_network_virus
rule 39 deny tcp destination-port eq 135
rule 39 comment wcn_network_virus
rule 40 deny udp destination-port eq 135
rule 40 comment wcn_network_virus
rule 41 deny tcp destination-port range 137 139
rule 41 comment wcn_network_virus
rule 42 deny udp destination-port eq tftp
rule 42 comment wcn_network_virus
rule 43 deny tcp destination-port eq 593
rule 43 comment wcn_network_virus
rule 44 deny tcp destination-port eq 4444
rule 44 comment wcn_network_virus
rule 45 deny tcp destination-port eq 707
rule 45 comment wcn_network_virus
rule 46 deny tcp destination-port eq 5554
rule 46 comment wcn_network_virus
rule 47 deny tcp destination-port eq 9996
rule 47 comment wcn_network_virus
rule 48 deny tcp destination-port range 1433 1434
rule 48 comment wcn_SqlServer_Slammer
rule 49 deny udp destination-port range 1433 1434
rule 49 comment wcn_SqlServer_Slammer
rule 50 deny tcp destination-port eq 3389
rule 50 comment wcn_WinRemote_Service
acl number 3003
description WCN_ACL_LAN_IN
rule 8 deny ip destination 121.9.211.201 0
rule 8 comment wcn_Poco
rule 9 deny ip destination 121.9.211.182 0
rule 9 comment wcn_Poco
rule 10 deny ip destination 121.9.211.186 0
rule 10 comment wcn_Poco
rule 11 deny ip destination 121.9.213.157 0
rule 11 comment wcn_Poco
rule 12 deny ip destination 121.9.233.71 0
rule 12 comment wcn_Poco
rule 13 deny ip destination 121.9.211.166 0
rule 13 comment wcn_Poco
rule 14 deny ip destination 121.9.211.180 0
rule 14 comment wcn_Poco
rule 15 deny ip destination 121.9.248.56 0
rule 15 comment wcn_Poco
rule 16 deny ip destination 121.9.248.55 0
rule 16 comment wcn_Poco
rule 17 deny ip destination 121.9.248.180 0
rule 17 comment wcn_Poco
rule 18 deny ip destination 221.11.114.227 0
rule 18 comment wcn_Poco
rule 19 deny ip destination 0.0.0.0 0
rule 19 comment wcn_Poco
rule 20 deny ip destination 59.39.59.7 0
rule 20 comment wcn_Poco
rule 21 deny ip destination 59.39.59.8 0
rule 21 comment wcn_Poco
rule 22 deny ip destination 59.39.59.12 0
rule 22 comment wcn_Poco
rule 23 deny ip destination 58.83.130.45 0
rule 23 comment wcn_Poco
rule 24 deny ip destination 58.211.84.138 0
rule 24 comment wcn_Poco
rule 25 deny ip destination 121.9.248.57 0
rule 25 comment wcn_Poco
rule 26 deny ip destination 211.98.110.124 0
rule 26 comment wcn_Poco
rule 27 deny ip destination 61.153.183.37 0
rule 27 comment wcn_Poco
rule 28 deny ip destination 61.153.183.38 0
rule 28 comment wcn_Poco
rule 29 deny ip destination 61.236.145.200 0
rule 29 comment wcn_Poco
rule 30 deny ip destination 8.12.197.124 0
rule 30 comment wcn_Poco
rule 31 deny ip destination 8.12.197.125 0
rule 31 comment wcn_Poco
rule 32 deny ip destination 208.111.144.245 0
rule 32 comment wcn_Poco
rule 33 deny ip destination 208.111.144.208 0
rule 33 comment wcn_Poco
rule 34 deny ip destination 202.75.213.121 0
rule 34 comment wcn_Poco
rule 35 deny ip destination 116.28.65.253 0
rule 35 comment wcn_Poco
rule 36 deny ip destination 208.111.144.214 0
rule 36 comment wcn_Poco
acl number 3004
rule 0 deny icmp
interface Aux0
async mode flow
interface Ethernet0/0
description WCN_INTERFACE_WAN
ip address 58.18.89.206 255.255.255.252
firewall packet-filter 3004 inbound
nat outbound 2000
nat server protocol tcp global 58.18.89.206 3389 inside 192.168.0.250 3389
interface Ethernet0/1
description WCN_INTERFACE_LAN
ip address 192.168.100.1 255.255.255.252
firewall packet-filter 3003 inbound
interface Ethernet0/2
ip address 192.168.100.5 255.255.255.252
interface NULL0
firewall zone local
set priority 100
firewall zone trust
add interface Ethernet0/1
set priority 85
firewall zone untrust
add interface Ethernet0/0
set priority 5
firewall zone DMZ
set priority 50
firewall interzone local trust
firewall interzone local untrust
firewall interzone local DMZ
firewall interzone trust untrust
firewall interzone trust DMZ
firewall interzone DMZ untrust
ip route-static 0.0.0.0 0.0.0.0 58.18.89.205 preference 60
ip route-static 192.168.0.0 255.255.224.0 192.168.100.2 preference 60
ssh authentication-type default password
firewall defend ip-spoofing
firewall defend land
firewall defend smurf
firewall defend fraggle
firewall defend winnuke
firewall defend icmp-redirect
firewall defend icmp-unreachable
firewall defend source-route
firewall defend route-record
firewall defend tracert
firewall defend ping-of-death
firewall defend tcp-flag
firewall defend ip-fragment
firewall defend large-icmp
firewall defend teardrop
firewall defend ip-sweep
firewall defend port-scan
firewall defend arp-spoofing
firewall defend arp-flood
firewall defend frag-flood
firewall defend syn-flood enable
firewall defend udp-flood enable
firewall defend icmp-flood enable
user-interface con 0
set authentication password cipher Y:O.H18#&N2.D:=;`8<.WA!!
user-interface aux 0
user-interface vty 0 4
authentication-mode scheme
user privilege level 3
set authentication password simple 123456
return
[FIRWALLF100-M]
[FIRWALLF100-M]
检查一下域间策略
怎么弄?
zhiliao_19813 发表时间:2018-03-14
