H3C S5130交换机同一个vlan下电脑的网络里发现不了共享设备
  • 1收藏,1428浏览
公司买了台华为路由器IP 192.168.1.1 ,一台H3C S5130交换机,
交换机准备分配4个VLAN
VLAN2      192.168.1.2  255.255.255.0  连外网路由器
VLAN10   10.10.0.254   255.255.255.0
VLAN20   10.10.1.254   255.255.255.0
VLAN30   10.10.2.254   255.255.255.0
VLAN40   10.10.3.254   255.255.255.0
问题 现在在路由器上也设置了路由表 上网什么都正常,但在同一个VLAN下资源管理器里面的网络下无法找到共享的电脑设备,同VLAN下 \\电脑名能共享,其他VLAN下 \\IP 也能共享 这是为什么啊  某些领导需求直接从网络里面点。
H3C配置如下:
# version 7.1.045, Release 3116
# sysname H3C # telnet server enable
# irf mac-address persistent timer irf auto-update enable undo irf link-delay irf member 1 priority 1
# dhcp enable dhcp server always-broadcast
# dns server 202.101.172.35
 dns server 202.101.172.47
# lldp global enable
 # password-recovery enable
# vlan 1 description VLAN 1
# vlan 2
# vlan 10 description VLAN 10
# vlan 20 #
vlan 30
# vlan 40
# dhcp server ip-pool vlan10 gateway-list 10.10.0.254 network 10.10.0.0 mask 255.255.255.0 dns-list 202.101.172.35 # dhcp server ip-pool vlan20 gateway-list 10.10.1.254 network 10.10.1.0 mask 255.255.255.0 dns-list 202.101.172.35 # dhcp server ip-pool vlan30 gateway-list 10.10.2.254 network 10.10.2.0 mask 255.255.255.0 dns-list 202.101.172.35 # dhcp server ip-pool vlan40 gateway-list 10.10.3.254 network 10.10.3.0 mask 255.255.255.0 dns-list 202.101.172.35 # interface NULL0 # interface Vlan-interface2 ip address 192.168.1.2 255.255.255.0 # interface Vlan-interface10 ip address 10.10.0.254 255.255.255.0 # interface Vlan-interface20 ip address 10.10.1.254 255.255.255.0 # interface Vlan-interface30 ip address 10.10.2.254 255.255.255.0 # interface Vlan-interface40 ip address 10.10.3.254 255.255.255.0 # interface GigabitEthernet1/0/1 port access vlan 2 # interface GigabitEthernet1/0/2 # interface GigabitEthernet1/0/3 # interface GigabitEthernet1/0/4 # interface GigabitEthernet1/0/5 # interface GigabitEthernet1/0/6 # interface GigabitEthernet1/0/7 # interface GigabitEthernet1/0/8 # interface GigabitEthernet1/0/9 port access vlan 10 speed 1000 duplex full # interface GigabitEthernet1/0/10 port access vlan 10 # interface GigabitEthernet1/0/11 port access vlan 10 # interface GigabitEthernet1/0/12 port access vlan 10 # interface GigabitEthernet1/0/13 port access vlan 20 # interface GigabitEthernet1/0/14 port access vlan 20 # interface GigabitEthernet1/0/15 port access vlan 20 # interface GigabitEthernet1/0/16 port access vlan 20 # interface GigabitEthernet1/0/17 port access vlan 30 # interface GigabitEthernet1/0/18 port access vlan 30 # interface GigabitEthernet1/0/19 port access vlan 30 # interface GigabitEthernet1/0/20 port access vlan 30 # interface GigabitEthernet1/0/21 port access vlan 40 # interface GigabitEthernet1/0/22 port access vlan 40 # interface GigabitEthernet1/0/23 port access vlan 40 # interface GigabitEthernet1/0/24 port access vlan 40 # interface Ten-GigabitEthernet1/0/25 # interface Ten-GigabitEthernet1/0/26 # interface Ten-GigabitEthernet1/0/27 # interface Ten-GigabitEthernet1/0/28 # scheduler logfile size 16 # line class aux user-role network-admin # line class vty user-role network-operator # line aux 0 user-role network-admin # line vty 0 4 authentication-mode scheme user-role network-operator protocol inbound ssh # line vty 5 63 authentication-mode scheme user-role network-operator # ip route-static 0.0.0.0 0 Vlan-interface2 192.168.1.1 # ssh server enable sftp server enable ssh user cdc_admin service-type stelnet authentication-type password ssh user manage service-type all authentication-type password scp server enable # acl number 2000 rule 1 permit source 10.10.0.254 0 # radius scheme system user-name-format without-domain # domain system # domain default enable system # role name level-0 description Predefined level-0 role # role name level-1 description Predefined level-1 role # role name level-2 description Predefined level-2 role # role name level-3 description Predefined level-3 role # role name level-4 description Predefined level-4 role # role name level-5 description Predefined level-5 role # role name level-6 description Predefined level-6 role # role name level-7 description Predefined level-7 role # role name level-8 description Predefined level-8 role # role name level-9 description Predefined level-9 role # role name level-10 description Predefined level-10 role # role name level-11 description Predefined level-11 role # role name level-12 description Predefined level-12 role # role name level-13 description Predefined level-13 role # role name level-14 description Predefined level-14 role # user-group system # local-user admin class manage password hash $h$6$00F/pUQOUaVUIstK$83O7gBuA/cDmiK/+jIjqt1Ck4lFn1gnA8iuUMn0hHtS+0h7R9hgJgZewUtdEfPyVKKzjS6U93Omt+8zmX+jSSw== service-type ssh telnet http https authorization-attribute user-role level-15 authorization-attribute user-role network-admin authorization-attribute user-role network-operator # local-user cdc_admin class manage password hash $h$6$f9Dv+kcrLEqpCE/g$pzFBCN7NqJOT/Jj3CT9CxdAHHHGMaWNG3jqPvCYzMDebyY26xAro+5bcCMHBJENWOu4i0YoZTBhEucp5c3zOQg== service-type ssh authorization-attribute user-role level-15 authorization-attribute user-role network-operator # local-user manage class manage password hash $h$6$WGlEg8aRX9aXsSXb$vV8u01eCXW/tvxO9aA6WlpKYIayUqj6G08Z/fMv/t6Vgmn9aoRE6zOU7E9boj7O1meIKmpn1RO9eY+UqNnafEQ== authorization-attribute user-role level-15 authorization-attribute user-role network-operator # ip http enable ip https enable # return
粉丝:14人 关注:4人
路由器上有写回程路由吗?
路由器上设置了静态路由表 4个10网段全部转发到了192.168.1.2上面,H3C上面也设置了个静态路由表 0.0.0.0 全部转发到192.168.1.1 这样设置对吗
zhiliao_yi9QLb 发表时间:2020-05-22
QAZWSX 九段
粉丝:21人 关注:4人
交换机是三层设备,只会识别报文二三层头部,再上层的不会识别,所以现场如果互ping没问题,说明是电脑层面的问题,建议排查
应该不是电脑问题 在公司原来的老网络下都是没问题的 插在这个新交换机下就发现不了共享
粉丝:4人 关注:24人
同一个vlan同网段都找不到共享主机,建议绕过交换机测试,两台电脑设置同网段地址网线直连测试,很大概率是电脑设置问题
电脑设置应该是没问题的 同工作组 在原来的老网络192.168.1.X里都正常
