S5110配置清零具体步骤方法?
2020-06-01提问
  • 1收藏,735浏览
S5110配置清零具体步骤方法?
https://forums.cnrancher.com/q_1061.html https://forums.cnrancher.com/q_1062.html https://forums.cnrancher.com/q_1063.html https://forums.cnrancher.com/q_1064.html https://forums.cnrancher.com/q_1065.html https://forums.cnrancher.com/q_1066.html https://forums.cnrancher.com/q_1067.html https://forums.cnrancher.com/q_1068.html https://forums.cnrancher.com/q_1069.html https://forums.cnrancher.com/q_1070.html https://forums.cnrancher.com/q_1071.html https://forums.cnrancher.com/q_1072.html https://forums.cnrancher.com/q_1073.html https://forums.cnrancher.com/q_1074.html https://forums.cnrancher.com/q_1075.html https://forums.cnrancher.com/q_1076.html https://forums.cnrancher.com/q_1077.html https://forums.cnrancher.com/q_1078.html https://forums.cnrancher.com/q_1079.html https://forums.cnrancher.com/q_1080.html https://forums.cnrancher.com/q_1081.html https://forums.cnrancher.com/q_1082.html https://forums.cnrancher.com/q_1083.html https://forums.cnrancher.com/q_1084.html https://forums.cnrancher.com/q_1085.html https://forums.cnrancher.com/q_1086.html https://forums.cnrancher.com/q_1087.html https://forums.cnrancher.com/q_1088.html https://forums.cnrancher.com/q_1089.html https://forums.cnrancher.com/q_1090.html https://forums.cnrancher.com/q_1091.html https://forums.cnrancher.com/q_1092.html https://forums.cnrancher.com/q_1093.html https://forums.cnrancher.com/q_1094.html https://forums.cnrancher.com/q_1095.html https://forums.cnrancher.com/q_1096.html https://forums.cnrancher.com/q_1097.html https://forums.cnrancher.com/q_1098.html https://forums.cnrancher.com/q_1099.html https://forums.cnrancher.com/q_1100.html https://forums.cnrancher.com/q_1101.html https://forums.cnrancher.com/q_1102.html https://forums.cnrancher.com/q_1103.html https://forums.cnrancher.com/q_1104.html https://forums.cnrancher.com/q_1105.html https://forums.cnrancher.com/q_1106.html https://forums.cnrancher.com/q_1107.html https://forums.cnrancher.com/q_1108.html https://forums.cnrancher.com/q_1109.html https://forums.cnrancher.com/q_1110.html https://forums.cnrancher.com/q_1111.html https://forums.cnrancher.com/article/99 https://forums.cnrancher.com/article/100 https://forums.cnrancher.com/article/101
粉丝:13人 关注:4人
可以删除配置文件,之后重启,选择不保存配置。
粉丝:14人 关注:0人
<H3C>reset saved-configuration
The saved configuration file will be erased. Are you sure? [Y/N]:Y  //确定删除保存的配置文件
<H3C>reboot
 Start to check configuration with next startup configuration file, please wait.........DONE!
 This command will reboot the device. Current configuration will be lost, save current configuration? [Y/N]:N  //不保存配置
This command will reboot the device. Continue? [Y/N]:Y   //继续重启
