S5110配置清零具体步骤方法?
2020-06-01提问
  • 1收藏,1217浏览
S5110配置清零具体步骤方法?
粉丝:14人 关注:4人
可以删除配置文件,之后重启,选择不保存配置。
粉丝:15人 关注:0人
<H3C>reset saved-configuration
The saved configuration file will be erased. Are you sure? [Y/N]:Y  //确定删除保存的配置文件
<H3C>reboot
 Start to check configuration with next startup configuration file, please wait.........DONE!
 This command will reboot the device. Current configuration will be lost, save current configuration? [Y/N]:N  //不保存配置
This command will reboot the device. Continue? [Y/N]:Y   //继续重启
