<H3C>display interface Ten-GigabitEthernet 3/0/1
Ten-GigabitEthernet3/0/1
Current state: DOWN
Line protocol state: DOWN(LAGG)
IP packet frame type: Ethernet II, hardware address: 84d9-3123-b800
Description: Ten-GigabitEthernet3/0/1 Interface
Bandwidth: 10000000 kbps //端口速率
(0)
可使用以下查看端口协商速率:
display interface brief
Speed一列代表协商速率 Duplex一列代表双工模式(A为自动协商、F为全双工、H为半双工)
可使用以下查看实时流量:
display counters rate inbound interface(入方向)
display counters rate outbound interface (出方向)
在Usage一列查看端口利用率,判断端口出入流量。
手动码字,如对您有帮助请采纳!
(3)
display counters rate inbound interface(入方向) display counters rate outbound interface (出方向) 这两条输入的时候流量永远卡在4%是啥意思?
display interface可以看到:
<Sysname> display interface ten-gigabitethernet 1/0/1
Ten-GigabitEthernet1/0/1
Description: Ten-GigabitEthernet1/0/1 Interface
Bandwidth: 1000000 kbps
Allow jumbo frames to pass
Broadcast max-ratio: 100%
Multicast max-ratio: 100%
Unicast max-ratio: 100%
IP packet frame type: Ethernet II, hardware address: 3822-d666-bd0c
IPv6 packet frame type: Ethernet II, hardware address: 3822-d666-bd0c
Loopback is not set
Media type is twisted pair, port hardware type is 10G_BASE_T
Port priority: 2
Flow-control is not enabled
The maximum frame length is 10000
Last link flapping: 6 hours 39 minutes 28 seconds
(0)
确定你的邮箱还未认证,请认证邮箱或绑定手机后进行当前操作
